Offline mario54i
#1 Posted : 22 May 2017 20:32:49(UTC)
mario54i
I found in my Re460 from a starter set that low headlights are four yellow LEDs, the external ones turn on with F0 and the internal ones with F6, and are brighter. No red lights.
I have never seen a real Re460 with high beam lights, all four low lamps shine the same way. Is the high beam real or a Marklin fancy function ?
#2 Posted : 22 May 2017 22:17:00(UTC)
Yes teh real Re 460s have high beam headlights.
Have seen them with my own eyes! Cool Wink
Offline mario54i
#3 Posted : 22 May 2017 23:07:15(UTC)
mario54i
Thanks Jacques
are the internal lamps only switched to high beam or all ?
#4 Posted : 23 May 2017 04:23:52(UTC)
The real Re 460 have two sets of headlights mounted in each headlight assembly, plus a red light. They also have a single light above the driver's cab which also has a red light.
I have seen Re 460s operating with only the two outer lights, with all four illuminated as well as with only one. I don't know why that lok was running at the front of a train with only one light on.
As far as I know, each light has both low and hi-beams, which can be selected by the driver.
The hi-beams have a longer focal distance than the low beams, enabling the driver to see further ahead than the normal lights.
For the record, I have never seen the red light above the cab in use.
Offline mario54i
#5 Posted : 19 June 2017 21:10:56(UTC)
mario54i
I'm playing with headlights of my Re460s.
The light arrangements (at real) I've found so far are
3 front white + 1 rear white - usual Swiss arrangement
3 front white/2 rear red for shuttle trains
2 front white + 2 rear white : shunting ?
1 front + 1 rear white for parking
3 front red + 3 rear red for emergency
is this correct ?
is there an arrangement with one red only ?
please advise
thanks
This page was generated in 0.368 seconds.
