Offline price james
#1 Posted : 19 May 2017 11:29:24(UTC)
price james
HELP
HAVE GOT A CLASS 55 LOCO
WILL RUN ON ANALOGUE
BUT CAN ONLY GET IT TO RUN ONE WAY WITH DCC LOCO CODE 0 NO DECODER
LOCO HAS SMOKE SOUND LIGHTS BUT DO NOT NEED THESE
HOW
DO 1 GET IT TO RUN BOTH WAYS
I AM CONVERTING LOCO TO BRITISH WD CLASS
HAVE SPARES FOR CLASS 55 LEFT OVER
TENDER WITH SOUND UNIT CAB TANKS ETC
SMOKE UNIT IN CHIMNEY
THANKS
JAMES
Offline Markus Schild
#2 Posted : 19 May 2017 12:19:25(UTC)
Markus Schild
Hi James,
Welcome to the forum.
The motor in that loco is an AC - Motor. to use it with that decoder it should be converted to a DC-Motor. You must dismantle the motor and replace the coil with a magnet ESU #51695: http://www.esu.eu/produk...behoer/permanentmagnete/ Then you can connect the motor to the decoder like any other DC-motor. That's the cheaper way.
If you want to improve the behaviour and the decoder is useable for such motors you can also replace the motor with a FAULHABER - motor. SB - Modellbau delivers a conversion - kit: http://www.sb-modellbau...._id=378&cPath=258_19
Markus
Offline price james
#3 Posted : 19 May 2017 13:03:23(UTC)
price james
thank you markus
I was told it was dc
that's perhaps why I got it cheap
will try to replace magnet as new motor is 255 euros
many thanks again
james
#4 Posted : 19 May 2017 13:10:34(UTC)
Hi, James,
Nice to see you CAPS LOCK key is working.
It's a motor for AC and DC. It takes a peak of 24 V to reverse the direction.
It works with DC, but cannot be used with DCC pseudo-address 0.
Offline price james
#5 Posted : 19 May 2017 16:18:02(UTC)
price james
Hi, James,
thanks tom will have to get new motor
james
Offline gcanton
#6 Posted : 29 June 2017 18:55:34(UTC)
gcanton
You could try a couple of diodes in the field windings, cheaper than a magnet, no mechanical dismantling either. The magnet is a mild cludge with these motors as they are designed for the 80 and Henschel diesel rater then the 38 and 55. I have posted a note elsewhere in this forum about fitting it.
They take a solid amp or so and a reasonable decoder is needed, the bulbs are 1.5v too so need careful interfacing or replacing.
Let me know if you want more help.
Graham
This page was generated in 0.316 seconds.
