Offline Graham HO
#1 Posted : 16 May 2017 05:00:49(UTC)
Graham HO
I have just finished assembling a Tams WD34 Decoder kit set, but the instruction manual is a little short on detail as to which of the input terminals (X8/X9) and (X17/X18) are 'Red and Brown' to match the usual Märklin convention - are there any builders out there that can clarify - many thanks in advance.
Also do not be mislead by an apparent 'typo' on page 41 of the English translation which refers to the cable connections for WD34 again - it should be SD34 which is an accessory/relay switching Decoder. The French, Dutch and of course German versions are OK
Offline LoeM
#2 Posted : 09 June 2017 21:00:33(UTC)
LoeM
Hello Graham,
On a German forum i saw a small picture of the Tams WD-34.
You can see the colors of the wires.
Furthet about the power supply:
tams wd - 34 power supply.pdf (142kb) downloaded 27 time(s).
You can see 8 and 17 are for the power supply, 9 and 18 for the DCC central unit. Eventually you can combine if you use only the DCC central unit.
Hope you can go further with this.
This page was generated in 0.397 seconds.
