#1 Posted : 15 May 2017 19:19:40(UTC)
Last night I was running my BR 85 that is equipped with a LokPilot decoder.
It was running very slowly in reverse over some track that is typically not used much and was somewhat dirty. The loco stopped and I went to it to clean the track a bit ahead of it. I suddenly noticed some smoke coming from the cab, which was not good as there is no smoke unit in this loco. I yanked it off the layout right away and opened it up on my workbench.
I could not see anything burnt, but I could smell some smoke on the motor.
I put the loco on the track without its cover and gave it current and sure enough smoke came out the motor again. I removed it quickly again.
I took the rotor out and looked at it and it seemed fine. I tried to move the gear train (which is very long in this loco) and there was a sticky part of the movement. I looked and looked for something caught in the gears, and cleaned them with a pipe cleaner. I did not find anything but after the cleaning they moved freely again.
I oiled them and reassembled the motor. The loco then ran fine again.
So, what I suspect happened is that some tiny thing (like a grain of ballast?) got caught up in the gears, preventing them from turning. With the motor then stalled, the decoder presumably increased the power to the motor based on the back EMF from the motor. This ran power through the single winding of the 3 pole rotor, and that caused it to overheat and start smoking.
Clearly I was lucky in seeing the smoke and stopping it quickly, saving the rotor.
Does anyone know if the load control of the LokPilots will keep increasing the power even if the motor is not turning at all?
If so, this can be a real issue and lead to burnt out rotor windings. I would hope that if the motor is not turning at all, the decoder would only apply current for short durations, but perhaps that would lead to less smooth starts... thoughts?
#2 Posted : 15 May 2017 19:43:12(UTC)
How would the decoder be able to tell if the motor is actually turning? One could have a current sensing system on the decoder to ensure that at a given voltage the expected current stays within a region, and kick in a safety stop if it looks like its hung up. Another option is a thermal resetting fuse to cut power on overheat, but you'd want it to signal in some way so you know to take the loco apart and diagnose.
#3 Posted : 15 May 2017 19:48:20(UTC)
Hi Dale, usually when this happens you will hear the coil buzzing as it draws more current.
If the stickiness is just temporary then the loco will jerk into motion after the voltage increases enough. A hard obstruction as you suspect will make it just draw maximum current until the coil overheats.
#4 Posted : 15 May 2017 20:47:26(UTC)
Modern decoders can determine the speed of the motor using what is called back EMF. This is how they implement load regulation or constant speed regulation - which the LokPilot decoders have.
#5 Posted : 15 May 2017 20:49:45(UTC)
the coil was removed and replaced with a permanent magnet when the decoder was installed. Back EMF is only possible with a permanent magnet motor.
The winding that were overheating was one of the three windings on the rotor, technically also a coil of sorts.
#6 Posted : 15 May 2017 21:17:57(UTC)
Sorry Dale, I was referring to the coils on the armature. What you call a winding. I'm well aware that we are talking about permanent field magnets.
Time and again I run into trouble with people from different backgrounds using different names for parts of a motor. What you call a rotor is in my book an armature. I've seen lots of references to rotors so I'm not saying you are wrong, but it's not what I learnt in University. I've also heard some unusual names for the commutator, the brushes and a few other parts...
Offline Danlake
#7 Posted : 15 May 2017 21:53:31(UTC)
Danlake
Hi Dale,
Interesting observations and a good question?
Hopefully someone knows the answer.
I believe with Lokpilot decoder you can adjust the amount of load regulation. I have noticed a tendency, among some US modeller, to limit the load regulation to mimic a more prototypically run where the loco slows down on grades unless the driver apply more throttle.
Brgds Lasse
#8 Posted : 16 May 2017 03:05:06(UTC)
Dale, I thought regardless of Back EMF, if your motor is not turning it will ruin it with current going through. however what is surprising the decoder has an overload protection and should turn off. you may take this further and ask the ESU forum.
#9 Posted : 16 May 2017 15:49:31(UTC)
I doubt it will turn off totally, but it should limit the current to some defined value.
Now wether that is a low enough current to stop the armature burning out when stalled is another question.
#10 Posted : 16 May 2017 21:56:06(UTC)
If the motor doesn't actually turn , there is no back EMF to detect. Wink
The decoder will thus go "full bore"on a blocked motor
But the output transistor is protected and will shut off thermally .
Your diagnosis of a blocked mechanism is probably the most plausible explanation.
Off hand I don't know of a way to fully protect a blocked rotor unless the output transistor is also current limited, but that adjustment would have to be user adjustable to adapt to the very different motors electrical characteristics.
(E.g a Faulhaber is a miser, an old Rivarossi big round motor is a hog!)
This page was generated in 0.559 seconds.
