Offline AmalfiCoast
#1 Posted : 13 May 2017 23:18:10(UTC)
AmalfiCoast
Does anyone know if the handrail/piping/ladder details on the Marklin steam locos are glued in place or are they just press fitted into small holes?
David
Offline rugauger
#2 Posted : 17 May 2017 17:10:42(UTC)
rugauger
I'm not sure for the newer models where these details are plastic.
On the older ones, they were metal wires that put through holes in the body and secured by bending flat on the inside.
Richard
Offline AmalfiCoast
#3 Posted : 18 May 2017 00:39:26(UTC)
AmalfiCoast
Thank you for the information, Richard.
David
Offline dickinsonj
#4 Posted : 19 May 2017 01:51:56(UTC)
David
David,
The small plastic details on almost all of my Märklin locos from the last 15 years are simply press fitted into small holes as you suggest.
On some of my models that seems to be fine but I still find stray parts from some models and collect them for later reattachment. I have a croc that will not hold onto its inductive magnet assembly for more than about 5 minutes!
When I put those parts back on my locos and coaches I use a small amount of glue if they do not need to be removed again for servicing. That eliminates the need to reattach them again, but it also means that I am less likely to lose a detail part that would be very hard to replace.
Edited by user 19 May 2017 13:48:18(UTC)  | Reason: Not specified
This page was generated in 0.336 seconds.
