Offline mb300e4m
#1 Posted : 09 May 2017 17:29:12(UTC)
mb300e4m
Does anyone know if Gaugemaster DCC23 decoders will work with a Marklin CS2 or 3+
Here are the specifications of the DCC23:
Most suited to N Gauge locomotives. Key features of this standard decoder include smooth operation, 14/28 speed steps, plug and play, transponder id-equipped, all mode programming, decoder reset CV, motor isolation protection, advanced consisting, 2 and 4 digit addressing and DCC compatibility This decoder is rated at 1 amp (2 amp peak) with 2 functions at 0.5 amps and measures 10.6 x 8.7 x 2.86mm
Thanks, this is for a friend.
Peter B.
Peter B.
In Sunny Florida most of the time.
Marklin, Trix Express, Trix Twin, Fleischmann, Liliput, Hornby Dublo, and Others, 2 & 3 Rail, AC, DC and Digital, Course Scale Wheels & Fine, 1935 to 1960s usually.
Offline franciscohg
#2 Posted : 09 May 2017 21:44:09(UTC)
franciscohg
Chile
Hi, should be no problem, both centrals speaks DCC, the problem could be motor comsuption, but for instance a LP V4.0 is rated for 1.1 A.
Offline mb300e4m
#3 Posted : 09 May 2017 22:38:26(UTC)
mb300e4m
Hi, should be no problem, both centrals speaks DCC, the problem could be motor consumption, but for instance a LP V4.0 is rated for 1.1 A.
Thanks very much Francisco, I will pass on the information to my friend. He has two N gauge locos fitted with these decoders, so I doubt the motor amperage will be a problem.
Peter B. BigGrin
Peter B.
Offline franciscohg
#4 Posted : 10 May 2017 00:55:36(UTC)
franciscohg
Chile
AhhhhhhhhhhLOL of course, for some reason i thought he wamted to fit them in h0 locos...0
This page was generated in 0.214 seconds.
