Offline Frank.Leisten
#1 Posted : 09 May 2017 04:51:49(UTC)
Frank.Leisten
Just purchased 2 Locomotives N gauge from Dapol in England. After receiving them I couldn't get them to run on my Marklin Central Station 2. Looks like I can change addresses on them but when I turn up the speed it just moves a little and I have no reverse control. Yes I bought them as DCC installed.
I live in America.
Thank you
Frank
#2 Posted : 09 May 2017 05:23:58(UTC)
Frank,
Welcome to the forum. Please do not add duplicate messages to the forum. Just post once and wait for an answer. I can't help you, but I am sure that someone else on the forum will be of assistance to you shortly.
#3 Posted : 09 May 2017 05:32:49(UTC)
Frank.Leisten
Frank,
Sorry Adrian. Won't happen again.
Frank
thanks 1 user liked this useful post by Frank.Leisten
#4 Posted : 12 May 2017 19:51:16(UTC)
Do you have other DCC N-scale locos that work fine with the CS2?
I just wonder - is DCC for N the same voltage as DCC for H0?
I'm "old-school" so I think about electricity first.... BigGrin
However, if you only run DCC - make sure that the MM & mfx protocols are disabled in the CS2, some decoders might have confusion issues when presented with signals with mixed digital talk to them...
#5 Posted : 12 May 2017 20:46:29(UTC)
Did you tested the lighting function on/off?
If they doesn´t works,you have default decoder.
I´m confuse when you wrote it moves little.
Seems power too weak to the motor?
#6 Posted : 12 May 2017 21:44:59(UTC)
I myself think it could be decoder "confusion" with protocols, depending on the installed DCC decoder, but we need more details from Frank.
Lights on/off is a good test to start with to settle that the DCC signal is received ok.
I myself would rather suspect "too much power" so the decoder goes into "shortcut protection mode", or a stuck motor/gears that need some "jogging"...
#7 Posted : 12 May 2017 22:01:23(UTC)
Frank.Leisten
Sorry no lights on these Locos. They both take address changes but when I throttle up they just go their own speed I can't control them and I can't change directions. Dapol will be sending me two decoders.
Frank
This page was generated in 0.541 seconds.
