Offline hwestl
#1 Posted : 05 May 2017 19:43:16(UTC)
hwestl
Hej
I have this setup with a MS2 and a Raspberry Pi to control the layout using a computer: Controlling a MS2 from a PC
I have created an app using Android Studio and as a simple remote control of my locs, it works perfectly. I can select different locs, I can switch on functions, set the speed and reverse the direction. It's just that all locs are hard coded in the program.
Now I would like to get the "loknamen" info from, in this case my MS2. I have got the sending to work, and I can see on the server or other VB6 programs that I have, that the request works as it should. But I can't get the app to receive that info.
Does anyboy have a example (preferable simple, because I'm not that experienced with Java) on how to receive these transactions from a CS2/MS2 in Java?
Håkan
#2 Posted : 05 May 2017 19:55:20(UTC)
I'm afraid my skills regarding the CS2/MS2 protocol are non-existent.
I suppose you already have this one:
https://www.maerklin.de/...S2_can-protokoll_1-0.pdf
Offline hwestl
#3 Posted : 05 May 2017 21:43:08(UTC)
hwestl
Yes I have that document. I have also got it to work with both sending the request and receiving the loc info in my VB6 program. I also have the request to work in the app, and I can see on the server that it sends the lok info back. It's the receive that I can't get to work. So I need some help from Java experts.
This page was generated in 0.223 seconds.
