Offline Incognito
#1 Posted : 15 April 2017 23:08:41(UTC)
Incognito
I have a 6017 booster powered by a 60055 transfer and the booster has bit the dustAngry If I get a 60174 booster can I power it with the 60055 transformer? I have a CS2 (60125) and it is powered by a 60065.
Alex
Offline dickinsonj
#2 Posted : 16 April 2017 01:47:49(UTC)
There has been a lot of discussion on power supplies and their applicability when used with various components and there are many subtleties involved.
But the short answer is NO. BigGrin
That booster requires a switched mode power supply and not a toy transformer.
And BTW I have several 6017 boosters that I want to move along to a new owner. Cool
Offline et1
#3 Posted : 16 April 2017 02:26:27(UTC)
et1
I would have to disagree with you Jim, I have three 60174 Boosters running with 60055 transformers. The 60055 transformers were the only option before the switched mode power supplies came outBigGrin I was however thinking of swithing over to switched mode power supplies.
Aloha,
Elliott
Elliott
CS2 4.1.2 (3), CS 2.04, 6021, 3x 60174 Boosters, L88, 2x 60881, 13x 6088(0) ,Windigipet 2015 Premium, Marklin K-track layout (in progress)
thanks 1 user liked this useful post by et1
Offline Incognito
#4 Posted : 16 April 2017 05:11:12(UTC)
Incognito
I have two 60174 boosters with 60065 power supplies and had 2 6017 boosters with 60055 transformers. I am now down to one 6017 booster and was hoping to be able to use the 60055 transformer instead of buying another 60065 for a new booster. The purpose of the 6017s was to power K83 switches. Can I use the track side of a 6021 for that? I already have the connect 6021 device and am currently using 6040 keyboards for turnouts.
Alex
#5 Posted : 16 April 2017 07:57:07(UTC)
The short answer is yes.
I would not expect any new issues when replacing a 6017 with a 60174 while keeping the transformer.
Offline Incognito
#6 Posted : 20 April 2017 21:02:26(UTC)
Incognito
I just noticed that in my original port I said that I had a CS2 (60125). It actually is a CS2 (60215).
I have one port still available on my 60125 terminal since I have 2 60174 boosters and a connect-6021 (60128). If I decide to replace both 6017 boosters, do I need another 60125 terminal or can I plug one of the new 60174 boosters in the last available port on the 60125 and the other in the 6017x port on the CS2?
Alex
This page was generated in 0.263 seconds.
