Offline Rwill
#1 Posted : 07 April 2017 23:07:31(UTC)
Rwill
Apologies if this too dumb a question! In my modest set up with hobby signals controlled by MS2 through a M84 and the normal isolating track - how do I set up to stop a push pull Regio set at the signal when it is going "backwards" without the train going way past the signal before the lok slider hits the isolating section?
#2 Posted : 08 April 2017 00:19:08(UTC)
Train sets sold by Märklin normally have a built-in slider switch-over: the pushing loco is fed from the slider in the control car.
This requires power conducting couplers and a switch-over module.
Offline Rwill
#3 Posted : 08 April 2017 10:35:57(UTC)
Rwill
Thanks Tom
However I guess my Silverfish commuter car set 4158/59/60 circa 1988 whilst having a slider for the directional lighting on the engineers cab doesn't go any further towards the set up you describe!
#4 Posted : 08 April 2017 10:50:34(UTC)
However I guess my Silverfish commuter car set 4158/58/60 circa 1988 whilst having a slider for the directional lighting on the engineers cab doesn't go any further towards the set up you describe!
That's right.
Either modify the train or the signal setup - or the mode of operation (stop the train manually or with PC control at the right spot).
I just had the idea that a circuit track near the signal could turn the track power off for a long stretch before the signal. This would allow push/pull operation with unmodified trains. That would work automatically.
Or a manual solution: Take a two position switch, mark it "pulled train" and "pushed train" and wire it such that "pushed train" extends the unpowered section in front of the red signal. All pushed trains must have a similar length.
Offline GlennM
#5 Posted : 08 April 2017 13:45:48(UTC)
GlennM
That's right.
yes great solution ThumpUp
#6 Posted : 08 April 2017 16:41:50(UTC)
My suggestion would be to have instead of one signal with a switchable zone and an isolation track, to install two signals with a switchable dead zone between the two. This way, a train entered the signal zone from either side would stop within the zone if both signals were red. The dead zone would have to be long enough for the entire train to be in the zone. The locomotive would keep pushing as long as the signal in the other direction remained green. When both were red, power would be cut off.
I wonder why they could not integrate some kind of feature into decoders that would detect a red signal ping and stop the train and then restart the motor when the signal pinged to green?
This page was generated in 0.302 seconds.
