Offline garben
#1 Posted : 30 March 2017 19:27:25(UTC)
garben
Greetings!
I have a not too old 60055 transformer that I would like to use to power lights. My question is how do I get connect it and what do I connect it too? I will not be using it to power anything other than lights. The connector looks like it goes into some king of connector box unlike the older transformers that had a yellow and brown input on the back.
Thanks.
#2 Posted : 30 March 2017 20:54:01(UTC)
Refer page 2 (bottom image) of the user manual.
https://static.maerklin....8e448e57271434542044.pdf
In this situation the 60055 is used the same as a 60052.
If the cable you refer to is like the one pictured in the manual (barrel connector) then it is for a Mobile Station or Central Station (60212)
The unit also came with a separate plug for use in bespoke wiring as you desire
If you do not have this, then simply remove the plug from the unneeded cable
60052
#3 Posted : 30 March 2017 21:02:52(UTC)
Hi- random question but dos anyone know a part number or how I can get the track side (not wall side) cable for these? Or at least the plug that goes into the transformer? I completely lost that and the plug with cable shown above on mine.
#4 Posted : 30 March 2017 21:24:24(UTC)
These sort of parts are listed on marklins site
Refer: http://www.maerklin.de/s...&artikelnummer=60052
I suspect that it would be quicker/cheaper to just procure the items from an (online) electronics store
Offline garben
#5 Posted : 31 March 2017 16:12:59(UTC)
garben
Thanks, that helps a lot. In this case, does it matter which of the wires from the dual end wire coming out of transformer I connect for power and ground? Excuse my ignorance but electrical is not my strong point and my wife would get made if I burned down our house.
Edited by moderator 01 April 2017 08:35:54(UTC)  | Reason: Not specified
Offline Crazy Harry
#6 Posted : 31 March 2017 19:38:19(UTC)
Crazy Harry
Look at the pictures in the user manual link posted by clapcott, you can see where they hook up the brown and yellow wires. If the outputs have a label, "0" is for brown and "L" is for yellow.
Edited by moderator 01 April 2017 08:29:23(UTC)  | Reason: Not specified
Offline garben
#7 Posted : 01 April 2017 04:28:00(UTC)
garben
The issue is that the transformer does not have any outputs that are shown in the manual shown above. It only have one input. See photo. It comes with a plug on one end that goes into the transformer and the barrel end is supposed to go into a mobil station or old CS. I can disconnect the wire with the barrel and then connect a "yellow and brown" wire to the plug. I'm just not sure which side to connect yellow and brown, or if it really matters.
Edited by moderator 01 April 2017 08:35:16(UTC)  | Reason: Not specified
#8 Posted : 01 April 2017 08:10:27(UTC)
Page two of the manual linked above shows yellow on the right and brown on the left. No issue.
Actually it does not matter.
#9 Posted : 01 April 2017 09:46:13(UTC)
A transformer gives pure Alternating Current (AC) which means there is no positive or negative terminal. You can connect the output either way.
When using more than one transformer at a time on the same layout it is then important to connect all of them in the same way to avoid "phase issues".
#10 Posted : 01 April 2017 09:57:50(UTC)
Only for transformers that provide track current for analogue operation.
No "phase issues" with digital operation or transformers for accessories.
Offline garben
#11 Posted : 02 April 2017 01:37:35(UTC)
garben
Perfect. Thanks!
thanks 1 user liked this useful post by garben
Offline Armando
#12 Posted : 06 February 2023 21:33:59(UTC)
Armando
On this 60055 topic, what can be the reason why such a transformer ceases to put out current?
The transformer is connected to the wall outlet, but there is no current being transferred to the CS2.
Armando García
Offline owidgie
#13 Posted : 06 February 2023 22:09:18(UTC)
owidgie
Hi Armondo, I fixed one of these a while back. From what I remember it had a failed Zener Diode in it. Once I replaced it the unit worked like new.
Rick
thanks 1 user liked this useful post by owidgie
This page was generated in 0.838 seconds.
