Offline Donb
#1 Posted : 29 March 2017 18:15:59(UTC)
Donb
On one of my 30501 locos , in the bogie with the slider pickup, the center wheel stops rotating intermittently. So i removed the slider and cover to have a look, while the front and rear wheel have metal springs, the center wheel does not. So there doesnt appear to be anything pressing the axle down so the wheels contact the track, other than gravity.
I have oiled the axle slightly, no difference.
The other loco in the set is ok.
Any thoughts?
Don
Best Regards,
Don
CS3, ( Commander is now retired) , C track and Z scale, mostly DB/DR and SBB, SJ
thanks 1 user liked this useful post by Donb
#2 Posted : 30 March 2017 05:16:42(UTC)
In order to properly function on model train narrow radii, the centre axle on the Maerklin Ae 6/6 (3050/3332/30501) is designed so that the wheels on that axle have different flanges that allow the bogie to rotate on the tight radii without forcing the train off the tracks.
I do not have the 30501, so I am basing my comments on my 3050. I am not familiar with springs on the wheels. There may be contacts to connect the axles to the body of the bogie insert, which then connects to the chassis, providing the return voltage (brown) contact between rail and motor.
If the axle is not freely rotating, it could be that something is stuck interfering in the motion of the axle, the axle could be bent (should be visible when rotating) or the slot in the bogie insert that the axle passes through may be compressing against the axle, impeding motion.
The part number to replace the bogie insert with wheels is E216980
If your model is within warranty, you may want to contact your dealer or service(at)maerklin.de
Offline Harryv40
#3 Posted : 30 March 2017 17:09:16(UTC)
Harryv40
Hi Don
My understanding is that the basic chassis on 30501-1 & 30501-2 should be the same, so I recommend e mailing Marklin to query the issue with them to query with them if a part is missing.
Harry
thanks 1 user liked this useful post by Harryv40
#4 Posted : 30 March 2017 17:51:44(UTC)
Any thoughts?
Don
Just like Mike C suggested, the middle axle should be running *very* freely.
If it's not the case, something must be caught between the wheels/axles and the chassis of the bogie.
It's easy to check!
Unscrew the pick up (long screw!) , and lift the contact plate.
Be careful not to break the contact wire!!
Please notice that this piece of plastic has notches corresponding to those on the bogie.
Any obstruction/ debris/ pich/ bend/ etc...should be easy to spot/diagnose now.
Reassemble in the reverse order.
Voilà.
Jacques
#5 Posted : 30 March 2017 20:47:26(UTC)
Just out of curiosity, make sure that the axle/wheels are not rubbing against the plastic brake pads of the outer part of the bogie.
I had a model where the part was slightly deformed and was rubbing against one of the wheels. A little twist with a pair of pliers and the wheel was not longer being impeded.
Offline Donb
#6 Posted : 01 April 2017 20:42:14(UTC)
Donb
I took it apart as Jaques suggested and it looks fine, no binding. The wheel appears to be free and spins freely by hand.
I checked the plastic part of the bogie, and even bent it slighly to make sure it isnt rubbing.
Result: no change.
So for some reason the wheel intermittently stops turning.
Ill monitor it, continue to look for a reason.
Thanks for the suggestions,
Don
Best Regards,
Don
#7 Posted : 02 April 2017 01:07:29(UTC)
Result: no change.
Don
Just a thought Don, seeing as you have two, why not swap that individual wheel set between the two Locos?, that may help isolate if there is an issue with the wheel/axle or with the truck frame.
Might not be apparent to the naked eye but could be a slight manufacturing burr left causing just enough friction.
Divide and conquer 🙂
Steve
Offline dickinsonj
#8 Posted : 02 April 2017 01:42:24(UTC)
Yes - I have had the same thing as well.
This page was generated in 0.463 seconds.
