#1 Posted : 16 March 2017 02:04:23(UTC)
H0 Scale and average person space to build - it requires compromises often on sizing and scale to reality.
For the train cars, I'm happy to have 1:100 scale cars that can make R1 curves.
For my train station, the room is also restricted, so why use up valuable space just to have more realistic sized station platforms widths vs the narrow ones the model kits provide. Works for me at least.
What other areas are compromises being made on sizing ?
Where is 1:87 scale from prototype most critical?
Another area is in towers, such as windmills or tv transmission towers. At real HO scale the TV tower from my city would just dominate the room - so a smaller scale version is acceptable. Another option I may end up going with is putting such landmarks into the photo-background to be stuck to the wall.
Offline gwolski
#2 Posted : 16 March 2017 03:10:11(UTC)
gwolski
Hard truth is that most of us will never have the space, budget, or time to create a full 1:87 replica of a real railroad. Compromises are how we get stuff done - where do we draw the line? How much of a model railroad do we need to model? How much space do we have?
The shorter cars are a great example - we need shorter cars to run on the smaller radius curves on our layouts. Unless, of course, you have access to something larger like a club layout. Boy do I love the look of my ACME and LS Models passenger coaches coupled tightly. They just need some really big curves to run well! I'd love to have a large modern passenger station to accommodate a loco and string of 10-12 these coaches. Not realistic for me, so we shorten the length of the train of already shortened cars and shorten the platforms as well. I still have a passenger platform and will spend the time/budget to add more realism through details. The viewer sees the details and ignores my shortened train.
Another technique many people use is selective compression of a familiar landmark or iconic structure to impart the flavor and feel of the real thing. I love the idea of background photos too! That's a great way to slide the real world into my reduced size model railroad. Look around - there are some very neat techniques to alter structures through selective compression to keep the feel of the original without feeling like it's miniature version instead. I have a paper model of the St Mary's church in Krakow that's basically Z scale - it's huge! I could probably plunk it down next to my HO trains and no one would blink an eye, but it's still way too big for the available real estate. Perhaps having the tops of the towers show over the trees of the Planty while my blue MPK trams run around would impart the flavor I want. Time for another trip for some photos!
I think we can make compromises pretty much anywhere - it's the challenge of the builder to figure out what makes most sense for the scene. What do you want to convey - there are days when I'd be happy with a plain table chock full of track for running, then other days I want one, well detailed scene that reminds me of one of my trips abroad.
I hope I didn't get too far off topic. We did mention shorter cars, selective compression, backgrounds. I think forced perspective is another great technique if well executed. Mirrors are great tools to make a small space appear larger.
As for the question on enforcing scale - I would keep the scenes and trains on the front edge all as close to 1:87, although shortened for operational considerations. The further back or remote on the layout, we can make use of the other techniques more easily. Up front and center should stay scale I think.
Helpful?
Cheers!
Gene Wolski
thanks 1 user liked this useful post by gwolski
Offline applor
#3 Posted : 16 March 2017 03:53:29(UTC)
applor
I think it depends on how much room you have and also how important realism is to you, how far you want to take it.
I am willing to run the 1:93.5 scale Marklin trains but would prefer not to if there was an alternative. Never touching 1:100. the 26.4m coaches in 1:87 look amazing.
My layout will be a reasonable size though and all my lines have realistic curves - no 360mm and the only 424mm radius is for my branch line station and bahnbetriebswerk switches with 64mm spacing.
Of course the spacing of things has to be compressed and my station platforms are about 1.4m (real size 121m) so they are likely shorter than in real life.
#4 Posted : 16 March 2017 08:31:49(UTC)
In real life there are wide platforms and narrow platforms.
When searching prototypes, we shouldn't look for the wide platforms of old stations. Modern stations or stations with limited space will have narrower platforms (that usually still have to be compromised for typical layouts).
I think I will model a smaller station where the long trains will simply pass through. You can still stop a long passenger train at a red signal even if not all coaches fit the platform.
And in real life there were trains that had scheduled stops at platforms where the final two coaches were beyond the platform and people had to jump.
The Märklin dining coaches marked 1:93.5 are usually 1:97.5 (33 mm missing to scale length). That's not far from 1:100.
Use 1:100 or 1:110 if that allows another coach at the platform or use 1:87 and take one coach less - or find an individual compromise.
Good to avoid the 360 mm radius if you want to use scale-length coaches.
It can't be done without compromises - at one place or another.
Offline waltklatt
#5 Posted : 16 March 2017 14:32:20(UTC)
waltklatt
If I may add, that chosing the amount of realism we want is also based on our time and resources without becoming overwhelmed.
More detailing consumes more time and resources and most of us have careers and obligations in life, that it becomes a struggle.
That's my perspective as to why my layout is not too overly detailed. A small 3' x 4' layout from Noch.
I too have a train station(Blausee-Mitholz), but it was designed to be alongside a straight track, and my layout doesn't have a long enough straight.
So the station has been modified for a curve.
Keep Marklining.......
thanks 3 users liked this useful post by waltklatt
#6 Posted : 16 March 2017 15:44:55(UTC)
Regarding narrow platforms: Sulzbach (ok, no ICE stop)
www.drehscheibe-online.de
Eimeldingen (ok, ICE is not stopping here)
www.badische-zeitung.de
Augsburg, platform #1 (ICE is stopping here)
www.architekturforum-augsburg.de
#7 Posted : 16 March 2017 18:21:36(UTC)
Let no one tell you you cannot have platforms that narrow -for sure. And even that a signal is in the wrong place (this one hadn't yet been relocated for the recently built commuter platform, due to permitting reasons).
In my case, as I'll be running loco + 3 car passenger trains, the narrower and shorter platforms should work well. Reading what others trade off willingly for what they value most is very interesting. Indeed, the only thing that matters is what matters to the modeler; what other modelers and observers feel is meaningless.
Forced perspective and mirrors are a tricky thing to use, since so much of the success of such an illusion depends on the position of the viewer.
For certain, when aiming to provide good photography options, where one controls the lighting and camera position, those techniques can work wonders.
thanks 4 users liked this useful post by Minok
Offline baggio
#8 Posted : 17 March 2017 02:15:47(UTC)
baggio
I love the pictures in this discussion. BigGrin
Does anyone have pictures of the INSIDE of a real Ice Train?
Offline Roland
#9 Posted : 17 March 2017 03:11:38(UTC)
Roland
Google is your friend, plenty to be found if you search :)
My Layout Build | Märklin CS3+ | K-track | Merkur | Viessmann | LDT | iTrain | Modeling DB + SBB
thanks 1 user liked this useful post by Roland
Offline baggio
#10 Posted : 17 March 2017 04:10:30(UTC)
baggio
Touche', Roland. BigGrin
Well, then, see what I found - and pay attention to the ...red button!
Ice Train - the real one
#11 Posted : 17 March 2017 04:40:38(UTC)
If you sit at the front you can watch the engineer/operator drive.
Offline Roland
#12 Posted : 17 March 2017 18:12:14(UTC)
Roland
For me, DB passenger trains are the main focus as I plan/build my layout as they're what I used to watch most while train watching as a child. I wanted station platforms that could accommodate my extended ICE and other 6-8 car trains as well as slim turnouts anywhere visible. For platform width I also wanted something a bit wider so my tracks surrounding platforms are separated by 2207 which allows for a decent platform width.
As a result, my Hauptbahnhof takes up a significant portion of my layout but I'm absolutely fine with that. It all comes down to personal preference. I would love to have an area for farmland but I have to sacrifice somewhere!
thanks 2 users liked this useful post by Roland
#13 Posted : 17 March 2017 22:34:26(UTC)
Can you clarify what this means? I'm assuming 2207 is the 156mm straight track, but I'm not sure how its dimensions are employed on your track/platform spacing.
Offline Roland
#14 Posted : 18 March 2017 00:39:21(UTC)
Roland
Hi Minok,
Here's what I mean:
The spacing is roughly 95mm between the center of the tracks so my platforms will be approximately 65mm in width.
thanks 3 users liked this useful post by Roland
Online PJMärklin
#15 Posted : 19 March 2017 07:06:19(UTC)
You sure can!
PJ
Offline Jabez
#16 Posted : 25 March 2017 06:14:15(UTC)
Jabez
I suppose the biggest compromise of all is track curve radius. With present day mainline radii in the order of Km then an HO model ICE would require radii in the order of tens of meters instead of 0.65m which is M R5, even R9 is only about 1.1m.
Next house I buy will have an indoor football pitch for my uncompromising HO layoutBigGrin
MinokH0
#17 Posted : 25 March 2017 07:24:20(UTC)
Some freight locos could handle the R9 radius, passenger trains would not take such sharp curves in real life.
The minimum radius depends on the speed. The radii used for high-speed lines are much larger than the radii used near main stations.
1000 m between distant signal and home signal or 3000 m braking distance are also challenging for H0 modellers.
Along with the curves these are areas where I have to accept compromises.
Offline baggio
#18 Posted : 25 March 2017 13:18:18(UTC)
baggio
I LOVE that picture of kissing Ice Trains, P.J.! BigGrin ThumpUp
Where was it taken?
Online PJMärklin
#19 Posted : 26 March 2017 05:08:10(UTC)
Where was it taken?
#20 Posted : 26 March 2017 05:59:49(UTC)
Someplace south or west if Frankfurt aM. I'm guessing.
And modern station. Mannheim doesn't look like that though.
ICE 772 Franz Kruckenberg
Basel SBB
Mannheim - Frankfurt(M)
Kassel-Wilhelmshöhe - Hannover
Hamburg-Altona
Online PJMärklin
#21 Posted : 26 March 2017 07:41:14(UTC)
Frankfurt ....... I'm guessing.
#22 Posted : 26 March 2017 07:45:53(UTC)
Last time I was in Germany, I did not travel through the Fernverkehr station at the Rhein-Main Airport during daytime. That would be my guess for the place where the photo was taken.
Look here:
http://www.railfaneurope...hof/Frankfurt__M__FF.jpg
http://www.railfaneurope...t/Fernbahnhof/FRA-mt.jpg
http://www.railfaneurope...bahnhof/airail2000_a.jpg
@Minok, the train probably heads from the Airport to Frankfurt (Main) HBF and from there to Kassel and then on to Hamburg. I don't think that trains from Ffm to Kassel would be routed via the airport as that would be quite a detour from the main ICE routes.
Online PJMärklin
#23 Posted : 26 March 2017 07:55:12(UTC)
Online PJMärklin
#24 Posted : 26 March 2017 08:08:58(UTC)
Look here:
Hello Mike, well found.
Yes, Frankfurt Airport and very convenient, as is the Hotel at the station if in reverse you train in and fly out home to Oz.
PJ
#25 Posted : 26 March 2017 21:51:00(UTC)
Look here:
Indeed. I knew Mannheim and Basel didn't look like that as they are all older outdoors only stations. Frankfurt Hbf also Is an older hall terminal station and doesn't look like that. So a stop along the route that isn't one of them major stops was likely. Frankfurt Flughafen seems like the candidate as it has no major stops between it and Frankfurt aM and it's an airport modern station. I'd never been in the airport rail station as my trips had me coming/going by car from the airport.
#26 Posted : 26 March 2017 21:54:43(UTC)
It's not Frankfurt aM Hbf as the sign indicate is the next major stop after leaving the station your presently in. It's a station before one gets to Frankfurt aM.
And the main Frankfurt station is a terminus station and is very old and under a roof looking nothing like this station.
Offline Jabez
#27 Posted : 28 March 2017 00:23:48(UTC)
Jabez
Just a memory of Frankfurt Flughafen up above the tracks. About 25 yrs ago I was waiting there for my connecting flight to Brussels when the next departure clattered up on the board, St Petersburg. That's funny I thought, a direct flight from Frankfurt to St. Petersburg Fl. Then the penny dropped, it was to what had been for so long Leningrad. That was the moment when I really knew that the USSR had gone for good.
#28 Posted : 28 March 2017 01:28:13(UTC)
would not fit on my layout in H0 scale, even with the whole house to use....
This page was generated in 1.142 seconds.
