Offline Alex H
#1 Posted : 25 March 2017 14:43:06(UTC)
Alex H
Years ago I created layouts using N gauge. With advancing years and not so good sight, and with a new grandson en-route I am thinking of creating a layout in HO gauge.
I have an N gauge plan that I would like to use, and wondered if it was possible to upscale from N to HO and if so, is there an easy way to achgieve this?
thanks 1 user liked this useful post by Alex H
Offline CanadianKid
#2 Posted : 25 March 2017 19:11:52(UTC)
CanadianKid
I don't know of any particularly good way to scale up a track plan from N to HO gauge. I'm in the process of using a Z scale plan to build an HO plan. If your using C track for the HO layout, I try to find the track pieces on the smaller gauge that correspond to pieces on the large gauge, if there is part #'s on the Z scale track plan. Not sure if that made a whole lot of sense, but perhaps some of the guys with track design software experience can add some useful information.
Best Regards,
Matthew
#3 Posted : 25 March 2017 20:10:43(UTC)
#4 Posted : 27 March 2017 11:02:17(UTC)
If your plan uses sectional track you may find that the geometry of the HO track system you intend to use may not match the N gauge version exactly.
The way I have adapted track plans in the past is to use the general shape of the plan I am copying and try and design it using the the HO track pieces instead. You may find you end up with a slightly different track arrangement.
Offline Alex H
#5 Posted : 27 March 2017 11:07:49(UTC)
Alex H
Thanks everyone
Yes Ray, I had just found that, so I will use one of the design programmes and copy it as closely as I can.
This page was generated in 0.548 seconds.
