Offline johnpatrickwack
#1 Posted : 21 March 2017 19:30:17(UTC)
johnpatrickwack
My very new 37105 is now having some problems getting started; lights and effects all work and it sounds like it's huffing and chuffing, but not moving until I physically push it a few cm or so down the track. Mysteriously, this happened right after my brother-in-law left after a visit and I know he was playing with the trains, but we'll be nice and just call it a coincidence. Anyway, I've done some research on this site but can't find any advice on what I might look at or do to correct this. The locomotive has probably run about 30-40 hours and I have not done any maintenance since I took it out of the box. Otherwise, it runs very well and is a beautiful locomotive with its running lights lit. Can anyone advise as to what to do?
Thank you, John
John P. Wack
Silver Spring, MD
Offline Leitner
#2 Posted : 21 March 2017 21:11:29(UTC)
Leitner
Taiwan, Province Of China
I have the same model and it always run quite smooth, but this is not helpful for you.
So, I have a few question, when you increase the speed from your MS or CS the engine of the lok do any noise?
Have you tried to apply some oil? (I'm quite sure it will not help though)
thanks 1 user liked this useful post by Leitner
Offline Dave Banks
#3 Posted : 21 March 2017 22:41:44(UTC)
Dave Banks
You have either a decoder issue or a winding in the armature that has broken or become disconnected. My suggestion is send back to your dealer if that was the method of purchase. Had a Taurus #39838 "Adria Transport" that did exactly as you mentioned. It went back to "M" & was duly replaced with a new one.
Dave...
D.A.Banks
#4 Posted : 21 March 2017 23:54:55(UTC)
johnpatrickwack
Dave...
Thanks for the advice - I did try a little oil but no change in behavior so since it's only 3 weeks old, I'm hoping AJCKIDS will exchange it for another one, I just contacted them. It is a very nice locomotive but I know things occasionally prove defective.
John P. Wack
Silver Spring, MD
#5 Posted : 22 March 2017 07:14:03(UTC)
Thank you, John
Hi John
This is usually only a small problem, and a well known one with locos that have been on the shelves for a while!Wink !
This loco still has the (very good!) older type motor with the so called "drum" commutator.
The behavior you observed is caused by one of the brushes not touching the commutator properly.
The little "nudge" gets it back in contact.
The usual cause is some oxidation/ contamination/wear on the brush(es) and/or the commutator.
Take the user manual and it will show you how to access/change the brushes.
Remove the brushes and clean them each with a drop of lighter fluid.
Then reassemble and run the loco for a few minutes.
**However** be aware that at the time this loco came out, there was a number of problems with the brushes themselves : they were too soft and rapidly clogged the commutator.
Simply install a set of fresh (and recent) brushes.
If that doesn't solve it, you'll need to have the commutator cleaned up.
But that is a different level of complex intervention altogether.
Let us know if/when you get to that point!
Hope this helps
Jacques
thanks 6 users liked this useful post by jvuye
Offline Torstein
#6 Posted : 22 March 2017 11:04:41(UTC)
Torstein
Hi John.
Are you sure the brake are not on in the play world modus, the behavior look like that. You have two functions buttons for the brake sound on this decoder and after some stops with sound the play world brake will turn on and the loc will not move before you take the brake off. Activate/turn off brake - for play world - function 10 when you run in standard modus.
The new BR 210 gas turbine have the same behavior.
Hope it helps.
Torstein
thanks 3 users liked this useful post by Torstein
Offline Tom Koh
#7 Posted : 22 March 2017 11:07:25(UTC)
Tom Koh
Dr Eisenbahn
I am going to try doing what you recommend on my Ae 6/6 that has exactly the same issue (my problem was posted a few days ago). The only difference is that when I push my lox it does not work but all the lights, sounds n other functions work
Tom Koh
thanks 1 user liked this useful post by Tom Koh
#8 Posted : 22 March 2017 13:01:41(UTC)
johnpatrickwack
Originally Posted by: Torstein Go to Quoted Post
Hi John.
Hope it helps.
Torstein
Ahh - this is good to know. I did try removing the loco in my MS2 and re-installing it, but it had no effect on the stalling issue unfortunately. Thanks for sending this - this is useful knowledge.
Cheers, John
John P. Wack
Silver Spring, MD
#9 Posted : 22 March 2017 13:08:31(UTC)
johnpatrickwack
Thank you, John
Hi John
Hope this helps
Jacques
Hi Jacques, Thank you for the advice - I've changed brushes and so forth on other locomotives, so I'll try the brush cleaning and see if they have deteriorated. I am heading out the door for a business trip, but I'll let you know if it works. AJCKIDS also suggested also that the brushes may not be well seated. A brief plug for AJCKIDS in the US - they have been a pleasure to deal with and gave me no hassle about requesting an exchange. But, I'll try cleaning the brushes first.
Thank you, John
John P. Wack
Silver Spring, MD
Offline baggio
#10 Posted : 22 March 2017 13:11:22(UTC)
baggio
A brief plug for AJCKIDS in the US - they have been a pleasure to deal with and gave me no hassle about requesting an exchange.But, I'll try cleaning the brushes first.
You may want NOT to do this - they may not like the loco being OPENED by a customer and might void the warranty. Ask them before you try.
#11 Posted : 22 March 2017 13:18:05(UTC)
Changing the brushes is covered by the locomotive instructions. It cannot possibly invalidate the warranty.
However I can't imagine that a locomotive that is still within the warranty period should need the brushes changing unless the loco has been left running for hours on end.
#12 Posted : 22 March 2017 13:22:02(UTC)
We are talking about a standard maintenance that is even described in the instructions pamphlet that comes with the loco.
Doing this does not void the warranty in Germany - and hopefully not elsewhere in the world.
The brushes should not be worn, but I had two or three locos where the brushes did not have enough tension on the commutator because the motor shield was also used as a holder for several cables and the cables interfered with the springs.
A little bending of the capacitor, gentle pulling the cables to and fro fixed the issue.
#13 Posted : 22 March 2017 13:38:35(UTC)
I had a similar issue with one of the brush holder springs catching on a blob of solder. In this case it was an "own goal" as I had done the soldering myself for a digital conversion. The point is that the spring was not free to push the brush with an even pressure and I had erratic running. Re-soldering more carefully with a small amount of solder did the trick.
Offline petestra
#14 Posted : 22 March 2017 15:22:02(UTC)
Hi John.
Hope it helps.
Torstein
Thanks so much, Torstein. That solved the problem on my SBB 37325 Lok. I had the brake on in the operations mode!
Cheers, Peter ThumpUp ThumpUp ThumpUp
Offline petestra
#15 Posted : 22 March 2017 15:23:39(UTC)
Thank you, John
Thanks, John. So glad you asked this question. Cheers, Peter Cool
Offline baggio
#16 Posted : 22 March 2017 16:09:32(UTC)
baggio
I still think calling the dealer ahead of time before opening the loco is a MUST, just in case.
#17 Posted : 22 March 2017 16:47:51(UTC)
It is a good idea to contact the dealer before sending a loco directly to Märklin for a warranty repair.
You have to open the loco to lubricate it before use. Why call the dealer before you open the loco?
Touch the springs the push the brushes with a pair of pliers or a small screw driver and check if that improves the situation. No force needed, just touch gently.
Loco can be run without boiler, so there is no need to reassemble it before the test run.
Offline franciscohg
#18 Posted : 22 March 2017 18:02:01(UTC)
franciscohg
Chile
Opening a loco is a must for every owner, always. These ladies are not iphones or such. They must be opened and disassembled to a certain level for basic maintenance and troubleshooting, Marklin even sells the tools for doing it.....,
thanks 3 users liked this useful post by franciscohg
Offline baggio
#19 Posted : 22 March 2017 19:03:52(UTC)
baggio
The proposition here is that the dealer will EXCHANGE the loco.
If I were the dealer and intended to resell it or send it to Marklin under warranty, I would like the peace of mind that the customer did nor open the loco and POTENTIALLY break something.
If Marklin sees inside the loco something amiss and knows that the customer opened the loco, Marklin may decline coverage claiming that the customer did the damage, even if it's not true in fact.
NOT telling Marklin that the customer operated on the loco would be unfair.
Therefore, do not open the loco, take it to the store and let them deal with the loco.
My usual 2 cents' worth. BigGrin
#20 Posted : 22 March 2017 19:37:13(UTC)
johnpatrickwack
I very much appreciate all the replies and I'm glad some people were helped out by them. I took the advice of contacting the dealer, AJCKIDS, and they felt that one of the armatures was not getting power. They said opening it up will not void the warranty and they could either exchange it for a new loco or send me a new armature to try. I seem to be having a streak of bad luck lately with locomotives, so I may just send it back although I think it's enjoyable to work on these things.
Cheers, John
John P. Wack
Silver Spring, MD
thanks 2 users liked this useful post by johnpatrickwack
#21 Posted : 23 March 2017 06:05:04(UTC)
Hi John.
Hope it helps.
Torstein
LOL, reminds me....
Offline mvd71
#22 Posted : 24 March 2017 10:36:52(UTC)
Cheers, John
Hi John,
The symptoms you are describing is consistent with a faulty armature in the motor. Having dealt with this on a few locals in the past, I would recommend sending it back for warranty assessment/repair.
Cheers.... Mike
Offline petestra
#23 Posted : 24 March 2017 11:01:50(UTC)
I fixed one of mine by slightly increasing the pressure onto the brushes by very little bending in of the brush springs. It worked on one of
mine if you know what you're doing well enough. Peter Cool
Offline dickinsonj
#24 Posted : 25 March 2017 00:48:19(UTC)
Thank you, John
Here is my vote for ADCKids as well!
They have treated me very well and they are now my go to dealer for all my Märklin needs.BigGrin
Offline baggio
#25 Posted : 25 March 2017 01:04:26(UTC)
baggio
This question is for the Administrator:
Is there anything wrong about the forum members endorsing certain shops that give outstanding service in each country and/or state/province?
We could come up with a list of best stores for members to go to.
Any thoughts on point?
#26 Posted : 25 March 2017 07:29:13(UTC)
The service quality provided by the shops does vary. It varies a lot with some shops.
Much customer feedback will be needed to get a good picture.
People are more likely to write about bad experiences, so getting a fair picture is not easy,
#27 Posted : 25 March 2017 18:00:26(UTC)
sjbartels
There is no problem with anyone recommending a dealer based on personal experience(s), this is not without precedent. However actual dealer advertising is not. Please post any such reviews or comments in the eBay dealers and review section of the forum.Thanks SJB
thanks 2 users liked this useful post by sjbartels
This page was generated in 0.750 seconds.
