Offline jsmatlak
#1 Posted : 20 March 2017 07:12:14(UTC)
jsmatlak
Hello- I recently purchased a very beautiful O gauge TWE 12930 20V from Germany. When I place it on the tracks on my 3-rail Lionel layout, the lights come on and it will only make a buzzing sound when the reverser switch is put in forward or reverse (it won't move). The seller described the unit as running. I read on another post on this forum that these units were designed to run on either DC or AC. Is there something that needs to be done to switch between AC and DC operation? The buzzing sound from the motor sounds like it is expecting to receive DC but is of course receiving AC on my layout.
Also, how do you remove the motor from the chassis? Can this be done without removing the roof?
Thank you for any advice.
thanks 1 user liked this useful post by jsmatlak
Offline Markus Schild
#2 Posted : 20 March 2017 11:52:19(UTC)
Markus Schild
Welcome to the forum.
Usually you can turn the part which looks like a whistle or an antenna on the roof. That's a hidden nut which holds a thread on the upper part of the boogie. Here are some pictures of the boogie: http://alte-modellbahnen...-eines-TWE-zerlegen.html
Often such models have been converted to DC to remote control the direction. A picture of the boogie outside the car would help.
Markus
#3 Posted : 20 March 2017 17:27:48(UTC)
What sort of track are you trying to run it on? With that pickup show it needs solid centre rail rail, not centre studs. To run it on modern track you will need to change to a modern pick up shoe.
If you are trying to run on centre studs i suspect the pickup shoe is catching on the studs.
#4 Posted : 20 March 2017 18:28:30(UTC)
This is O gauge , Alan! Wink
#5 Posted : 20 March 2017 19:10:05(UTC)
Ah .. Blushing
Offline jsmatlak
#6 Posted : 21 March 2017 04:52:28(UTC)
jsmatlak
Markus
Markus- thank you for your reply. I am still not clear on how to remove the roof. On the clockwork TWE 930 there are two tabs which hold it on:
On the TWE 12930 these tabs are also there (and they are already straight), but the roof does not want to come off in the same way. Is there something besides these two tabs that is holding on the roof?
Thank you
Offline jsmatlak
#7 Posted : 04 April 2017 05:21:41(UTC)
jsmatlak
Markus
I have solved the question- the seller explained that to remove the roof you simply loosen the silver-colored standoff located at the center of the train. After taking out the power unit the added rectifier was obvious. I removed it and re-established the original wiring using the photos you provided and it now runs perfectly. Thanks!
This page was generated in 0.443 seconds.
