Offline fossie
#1 Posted : 15 March 2017 12:10:29(UTC)
fossie
Dear all
My marklin 36242 br24 steam locomotive suddenly runs vey fast in one direction only. It can't be slowed or reversed. All the lights and sounds work. I opened the model up and could smell a burning smell from the decoder. I have tried to reseat it to is daughter board and the problem still occurs. The decoder part number is 194194.
Does anyone know of another manufacture of decoder I can use eg plug it in to the daughter board. or will I have to send the model back to Marklin for repair.
Andy
#2 Posted : 15 March 2017 13:13:55(UTC)
Hi, Andy!
Märklin (MSD), ESU (V4 M4), Zimo, maybe more.
But with those generic decoders, you will have to upload the correct sound (some dealers will do that if you ask them) and you will have to configure the decoder (can be done with a Central Station, but will be tedious with a Mobile Station 2).
Judging by your question I assume you do not have much experience with installing/configuring sound decoders.
So either try it, learn it, and save same money - or send the loco for repair.
Offline fossie
#3 Posted : 15 March 2017 16:14:19(UTC)
fossie
Hi, Andy!
Hi tom
Thanks for your reply.... I want a decoder that plugs in via the 21 pin interface on the daughter board as this contains the rear led lights and wires to the motor... Etc.... No soldering. I was thinking of buying the marklin decoder p/n 60975 as this has the interface and has the steam sounds. Do you think this will be suitable to plug in and use?.
Andy
#4 Posted : 15 March 2017 16:45:17(UTC)
You can plug the decoder in and the loco should drive with lights and sound if just the old decoder is damaged.
Some configuration work may be necessary to get the correct number of chuffs per rotation &c.
I don't know if there is a specific BR 24 sound project that can be uploaded to 60975 decoder and which differences exist between the BR 24 sound and the generic 60975 sound.
Long story short: it should run. Fine-tuning can be postponed.
Offline fossie
#5 Posted : 17 March 2017 16:45:23(UTC)
fossie
Dear all
Thanks for your reply son this. Does any one know how long Marklin warranty lasts. The model was purchased from modellbahn lippie on the 23/10/13. If it is 5 years then I am going to return it to marklin to repair.
Andy
#6 Posted : 17 March 2017 18:43:57(UTC)
The warranty is 5 years for MHI items from the past few years, including this one.
This page was generated in 0.394 seconds.
