Offline SteamNut
#1 Posted : 11 March 2017 12:51:32(UTC)
SteamNut
I want to make some loads for my flat cars consisting of steel pipes, black and galvanized. Here in the US when I go to a plumbing supplier they come in 10 foot sections with thread protectors or 21 foot sections with couplings on the one end. This would be true up to 4 inch inside diameter pipe which would be the largest pipe on the load - Fred
Offline Unholz
#2 Posted : 11 March 2017 16:17:57(UTC)
Unholz
You mean the length of the prototype pipes? I think 6 or 12 meters are standard.
#3 Posted : 11 March 2017 17:00:40(UTC)
Maybe you should read the Government Pipe Specifications first:
1. All pipe is to be made of a long hole, surrounded by metal or plastic, centered around the hole.
2. All pipe is to be hollow throughout the entire length -- do not use holes of different length than the pipe.
3. The ID (Inside Diameter) of all pipe must not exceed their OD (Outside Diameter) -- otherwise the hole will be on the outside.
4. The pipe is to be supplied with nothing in the hole, so that water, steam or other stuff can be put inside at a later date.
5. All pipe is to be supplied without rust; this can be more readily applied at the job site. (NOTE: Some vendors are now able to supply pre-rusted pipes. If available in your area, this product is recommended as it will save a great deal of time at the job site.)
6. All pipe over 500ft (150m) in length should have the words "LONG PIPE" clearly painted on each side and end, so the contractor will know it's a long pipe.
7. Pipe over 2 miles (3.2km) in length must also have the words "LONG PIPE" painted in the middle so the contractor will not have to walk the entire length of the pipe to determine whether it is a long or short pipe.
8. All pipe over 6ft (1.83m) in diameter must have the words "LARGE PIPE" painted on it, so the contractor won't mistake it for a small pipe.
9. Flanges must be used on all pipe. Flanges must have holes from bolts that are quite separate from the big holes in the middle.
10. When ordering 90 or 30 degree elbows, be sure to specify left-hand or right-hand, otherwise you will end up going the wrong way.
11. Be sure to specify to your vendor whether you want level, uphill or downhill pipe. If you use downhill pipe for going uphill, the water will flow the wrong way.
12. All couplings should have either right-hand or left-hand threads, but do not mix the threads. Otherwise, as the coupling is being screwed on to one pipe, it is being unscrewed from the other.
13. All pipes shorter than 1/8in (3mm) are very uneconomical in use, requiring many joints. They are generally known as washers.
14. Joints in pipes for water must be watertight. Those pipes for compressed air, however, need only be airtight.
15. Lengths of pipes may be welded or soldered together. This method is not recommended for concrete or earthenware pipes.
16. Other commodities are often confused with pipes. These include; Conduit, Tube, Tunnel, and Drain. Use only genuine pipes.
thanks 12 users liked this useful post by Purellum
Offline ROBMODEL
#4 Posted : 11 March 2017 17:55:20(UTC)
ROBMODEL
Views messages in topic : 45
Standard pipelengths are: up to and including 4inches 6 and 12 meters above 4inches 6 meters. regards Rob
Offline SteamNut
#5 Posted : 11 March 2017 19:47:02(UTC)
SteamNut
That is what I expected. I could make a load of copper tubing, however the flat cat would be empty as it would have fallen off somewhere.
#6 Posted : 11 March 2017 21:40:22(UTC)
The great thing about standards is that there are so many to chose from.
Pipes in Europe are 87 times longer than the ones on your Märklin goods cars.
#7 Posted : 12 March 2017 00:08:43(UTC)
In the UK it would have been filched by the metal thieves ... BigGrin BigGrin BigGrin
Offline SteamNut
#8 Posted : 12 March 2017 02:33:42(UTC)
SteamNut
In Brooklyn New York they say it fell off the truck.
#9 Posted : 12 March 2017 02:50:24(UTC)
In Western Sydney they say that the truck fell off the pipe..Scared
Offline Wildrose-Wally
#10 Posted : 12 March 2017 05:01:29(UTC)
Wildrose-Wally
In Russia the pipe drives the truck. Glare
thanks 1 user liked this useful post by Wildrose-Wally
#11 Posted : 12 March 2017 16:55:05(UTC)
Another thing to consider is that for any load of pipes, they are likely to be 1m longer than the available goods wagons.
This page was generated in 0.602 seconds.
