Offline Nielsenr
#1 Posted : 07 March 2017 16:59:18(UTC)
Nielsenr
I recently acquired some MTH Premier O Gauge locos on sale. I plan to use my CS2 using boosters (to protect the CS2) and run them in DCC. My Marklin 60055 and 60065 power supplies work, but the amperage is a little low. I know I can use a Marklin 60101 5 amp power supply, but then I will need to use a converter to use on the 120v power here in the USA. Has anybody used a different 120v power supply that works with the CS2 that I can avoid using a converter? Marklin likes to talk about using the CS2 to run LGB or Marklin Gauge 1 locos but they don't offer a 5 amp 120v power supply.
Any ideas or thoughts would be appreciated ...
Robert
Offline blid
#2 Posted : 07 March 2017 19:17:41(UTC)
blid
Maybe the LDT booster DB-4 with its power supply is worth looking at (120VA; 110V - 240V, 50/60Hz). http://www.ldt-infocente...wiki/doku.php?id=en:db-4
I have 230V and use Marklin 60101 for OneGauge and LGB 50110 for DCS OneGauge or O Gauge (MTH Premier like you).
#3 Posted : 08 March 2017 15:53:28(UTC)
Robert
I would expect the 60101 to provide full power output on 120V, anyone who doesn't build wide input switchmode power supplies is looking for low profits these days. The reason they rate it at 230V only is because it has a european plug on it.
I would certainly try it, I don't believe you will damage the power supply by doing so.
Offline Nielsenr
#4 Posted : 08 March 2017 22:16:56(UTC)
Nielsenr
/quote]
Thanks for the idea. I already have Marklin boosters and was hoping somebody had used a different power supply that worked on US 120v.
It would probably be cheaper to just buy the 60101 and a voltage converter.
Robert
Offline Nielsenr
#5 Posted : 08 March 2017 22:19:51(UTC)
Nielsenr
Robert
It is something to try, but I would have thought someone would have tried that already. Of course if it didn't work, I wold just need to buy the voltage converter ...
Thanks for the reply ...
Robert
This page was generated in 0.270 seconds.
