#1 Posted : 07 March 2017 09:35:44(UTC)
I bought this Märklin SBB loco 36627 with a sound decoder but for some odd reason I can only get 4 functions from it, why is this (using an ESU lokprogrammer) with the decoder no. 24. I haven't tried it with my ECoS
regards.,
#2 Posted : 07 March 2017 11:10:26(UTC)
Going to show my ignorance here... Should the ESU lokprogrammer work on Marklin decoders?
#3 Posted : 07 March 2017 11:25:16(UTC)
Ray, you can't program or read the decoder but you can enter the decoder number (24), select motorola, lights and the first 4 functions work.
#4 Posted : 07 March 2017 11:48:31(UTC)
OK, I see now.
Perhaps it is because you have to run it in motorola mode that you only see the first 4 functions. Do you have the option to try the other functions using the next motorola address like I used to do on my 6021?
I would imagine that your Ecos will register it as mfx and allow the use of all functions.
#5 Posted : 07 March 2017 14:05:49(UTC)
OK, I see now.
its a bit odd, it shows 16 functions so they should be available but as you said most probably the ECoS will pick them up, I don't have any Märklin sound decoders and this is the first one I've got supplied with the loco. just have to set up my ECoS again and see what is happening.
I've just realized what you've said using the next address and so on, will try it, never entered my mind, tried it but no respond
I also added more led's, very tiny ones, 0402, cant hardly see them, used resistors and successfully soldered the leds onto the front circuit board, this should enable me to use a high beam and I may tinker with the Swiss lighting schematic but this will be a bit risky and i think I leave it as it is however i will purchase another 2 axles with rubber tyres and this gives the loco 4 rubber tyres over 4 axles
#6 Posted : 07 March 2017 14:21:23(UTC)
The ESU LokProgrammer can program any DCC decoder that supports CV programming. Märklin locos normally have DCC disabled in the decoder.
The second address typically is 255 (for F5 through F8). The other addresses default to 254 (F9 through F12) and 253 (F13 through F16), but in most cases only 2 addresses are active.
IIRC the LokProgrammer shows F0 through F28, but for MM addresses only F0 through F4 are supported (a protocol limitation).
It's definitely worth trying address 255 and playing with F1 through F4 for this address.
#7 Posted : 07 March 2017 16:34:25(UTC)
thanks for this Tom, unfortunately nothing has worked, under the mobile station 1 I've got 7 functions per instruction booklet but this is it. it registers under mfx I've added 2 more leds with resistors but I don't seem to be able to activate them even with mobile station, suppose this is the drawback buying Märklin sound decoders you can't alter them or activate aux functions.
#8 Posted : 07 March 2017 16:56:48(UTC)
You can alter them with a Central Station or ECoS, but not with a Mobile Station or CU 6021 or Intellibox.
Offline dickinsonj
#9 Posted : 10 March 2017 03:43:20(UTC)
Alternatively you can update the sound files and alter the CVs for Märklin sound decoders with a 60971 decoder programmer, although that does require removing the decoder from the Loco.
#10 Posted : 11 March 2017 03:12:49(UTC)
Views messages in topic : 8,369
regards.,
You can't change the settings with the ESU Lokprogrammer. If you set the unit to test bench, you can activate the various functions. You first have to select the system. In MM, you can only access settings Function, F1-F4. In DCC, you can access many more. The 36627 probably works with MM and MFX. I don't know if it understands DCC, so you would have to have a Lokprogrammer that understands MFX.
#11 Posted : 11 March 2017 05:39:38(UTC)
regards.,
Mike I thought this as well, when I get my ECoS fired up I'll see what happens there,
#12 Posted : 24 March 2017 09:07:14(UTC)
Hi, nothing happened with my ECOS, it has to be motorola mode and this restricts it to 4 functions, couldn't program it sofar except the decoder address haven't tried the others CV's.
Märklin sound decoder sets 60948/60949 (Digital components and Software reviews)
by H0 04/08/2013 23:22:37(UTC)
This page was generated in 0.671 seconds.
