Offline Ricwolt
#1 Posted : 27 February 2017 07:40:20(UTC)
Ricwolt
I have started a marklin layout on two separate levels. Two tracks run separate from each other each with their own controllers:
A/
One controller is a 6021 coupled only to a transformer.
B/
The other a 6036 f80 coupled to a central unit and two keyboards for points /signals etc
I recently bought two loco's (steam and diesel) and all works fine- sound horn- engine-steam etc
problem:
Although everything works fine on controller A, Speed/slow brake/horn/whistle/light/diesel and steam sound etc; if I place the loco's on the other track powered by controller B
I only get speed and slow brake plus light, but NO sound on either loco.
Could anyone tell me what may be wrong here or if there is something I need to do.
your help will be very much appreciated
kind regards Richard
#2 Posted : 27 February 2017 07:50:43(UTC)
Hi, Richard!
The Central Unit 6020 only supports F0 (but IIRC F1 should always be on with some locos, but F2 through F4 will always be off for locos).
A 6036 connected to the 6020 has F1 through F4, but I think only very few Märklin models (no locos) support those in this configuration.
#3 Posted : 27 February 2017 15:01:27(UTC)
Hi, Richard!
With a 6020 F1 through f4 are only for the accessory wagons such as the 4998 and 4999 and 49960? wagons.
Offline Ricwolt
#4 Posted : 27 February 2017 23:41:52(UTC)
Ricwolt
Hi, Richard!
Thankyou,
does that mean I need to get a different controller or can adjustment be made?
regards Richard
#5 Posted : 28 February 2017 07:41:30(UTC)
Hi, Richard!
Do you need that separation?
You can connect the 6036 to the 6021 and power tracks A and B from the 6021.
This will give you F0 through F4 on both tracks. If you need more power, then a 6017 or 66045 will give you that.
Sound not working - BR 261 - 54323 (Big scale)
by hennebror 27/01/2021 02:07:30(UTC)
This page was generated in 0.553 seconds.
