Offline Rocca
#1 Posted : 19 February 2017 10:32:47(UTC)
Rocca
Hello, my dearest friends,
I'm waiting from E-bay for a Kokko 8852 and a BR 103 n. 8854, but I own an 8858 BR 151 too. So, my question is: how I have to turn the powering to the overhead? Need I to open the chassis? And what will I find in the interior? A screw? Or what else?
Then, another question. I've till now used my layout powering it by the track, but I want now to upgrade it to catenary. I realized too late, apparently, that the direction of the train is opposite regarding to the Control-Knob of the Trafo. It means: control-knob: right / trains left; control-knob: left / trains right. So will this situation make any trouble with the catenary? I've read I'll have to connect the catenary mast to the ground of the trafo.
Thanks in advance for any advice!
Stefano Rocca
Offline Wal
#2 Posted : 19 February 2017 17:13:48(UTC)
Wal
G'day Stefano,
Only the newest loco's have the screw hidden below the outer chassis. The screw is located in the middle of the top of the loco. When turned in one direction power is taken from the wheels, the other way power is from the pantograph. One of your catenary masts has to be a feeder mast. It has a brown wire which you connect to a second transformer. That way you can control two locos on the same track. One draws power from the catenary and the other from the track. In theory you can run them in opposite directions because the operate from separate transformers. But that may lead to chaos.
When I was running analogue it worked well for me.
Wal
Offline Rocca
#3 Posted : 19 February 2017 18:16:20(UTC)
Rocca
Thank you so much fore the tipps, dear Wal.
Do you mean screw like this in this picture of the Loco I've in my hands now?
Have I to turn it?
(Sorry, about the pic being int wrong sense, but I don't know to place it in the right position Blushing Blushing )
Stefano Rocca
Offline Carim
#4 Posted : 19 February 2017 20:45:53(UTC)
Carim
Carim
Offline Carim
#5 Posted : 19 February 2017 20:48:46(UTC)
Carim
I also attach an operations manual - this is for a newer loco than your one and so the screw is inside rather than on the roof, but the principles still are the same.
88587 operations manual.pdf (1,089kb) downloaded 15 time(s).
Carim
Offline Rocca
#6 Posted : 19 February 2017 20:59:07(UTC)
Rocca
Thank you a lot, dear Carim, for the explanation and for the operations manual and, obviously, for having put the pic in the right position!
Stefano Rocca
Carim
thanks 1 user liked this useful post by Rocca
This page was generated in 0.494 seconds.
