Online Donb
#1 Posted : 06 February 2017 06:22:01(UTC)
Donb
I have the new MS 2 60657 and 60116 connector box, and quite frequently, at least once per running session, the screen will go off and then turn on again, all while the trains keep running. The only problem is the headlight indicator turns off, but the headlights on all running locos are on.
Is this a known quirk with this controller? I am thinking it is resetting itself for some reason?
Don
Best Regards,
Don
CS3, ( Commander is now retired) , C track and Z scale, mostly DB/DR and SBB, SJ
#2 Posted : 06 February 2017 06:37:13(UTC)
Hi, Don!
Does it show the Märklin logo when it comes back?
The track box should switch off in case of overload before the power supply switches off.
If with your set the power supply (which one?) switches off before the track box then the MS2 will reboot. This is not the expected behaviour.
Do the trains keep running all the time? Or is there at least a short stop?
Did you try the MS2 in both sockets of the track box?
Online Donb
#3 Posted : 06 February 2017 19:02:07(UTC)
Donb
Hi, Don!
Hi Tom,
Yes the Marklin logo appears during reboot.
My power supply is 60055.
The trains (3 locos) keep running smoothly through the reboot, no stopping, which seems strange.
I'll try the other socket on the track box tonite and report back.
I did not have this issue with the previous 60652 MS and 24088.
Don
Best Regards,
Don
#4 Posted : 06 February 2017 19:27:44(UTC)
I've had similar behaviour when there is not a good contact between the MS2 plug and the track box. This can be caused by some dirt or oxidation on the pins or on the socket. Re-seating the plug a few time might clear it.
Online Donb
#5 Posted : 07 February 2017 17:56:46(UTC)
Donb
I changed the MS2 plug to the 2nd socket (right) in the connector box and didn't experience a reset.
I will continue to monitor this, but its encouraging. I'll switch it back and forth to verify the problem in the left socket.
Perhaps also by doing this the connection in the left socket may improve, per Ray's suggestion.
It didn't occur to me to try this, as I thought , as in the 24088, that the left socket is for the master controller. I recall trying the right socket in the 24088, but the MS 1 didn't function, error screen. Obviously this rule does not apply to the new connector box.
I will return the connector box if the problem persists.
Thanks very much for your help here!! BigGrin
Don
Best Regards,
Don
#6 Posted : 08 February 2017 08:23:29(UTC)
The 24088 has a 10-hole socket and a 7-hole socket, so the MS1 only fits on the left without adaptor cable. The MS1 on the right socket only works when there also is one in the left socket.
But yes, obsolete rules stick in your head and you still use the left socket because you always did.
This page was generated in 0.426 seconds.
