Offline AtlanticMan
#1 Posted : 07 February 2017 02:26:20(UTC)
AtlanticMan
I am now just setting up my Marklin layout again and would like to use catenary. I want to continue to use M-track since I have a fair amount of M-track. Can the new Marklin posts, masts, and catenary be used with M-track? Thanks.
#2 Posted : 07 February 2017 02:34:00(UTC)
sjbartels
No, they cannot. However posts for M Track can be readily found on ebay
Offline franciscohg
#3 Posted : 07 February 2017 02:58:51(UTC)
franciscohg
Chile
And why you should not be able to use those poles with M-track? Cant you just screw them to the base board, as if it where K-track? The clips are obviously not compatible
#4 Posted : 07 February 2017 03:32:30(UTC)
sjbartels
Potentially yes, that's possible. My post was a reference to stand alone, as it comes packaged
thanks 1 user liked this useful post by sjbartels
Offline franciscohg
#5 Posted : 07 February 2017 03:36:35(UTC)
franciscohg
Chile
Worse than that it is expensive, i would try first directly at Sommerfeldt, or try other brands perhaps, thinking that perhaps when i build my layout i will use the catenary.i have only for hidden sections, and try other brands for the exposed ones
#6 Posted : 09 February 2017 07:05:27(UTC)
Is the Viessmann version less costly than what Maerklin is offering under their brand?
Offline franciscohg
#7 Posted : 09 February 2017 11:47:57(UTC)
franciscohg
Chile
Sommerfeldt, yes, a couple of euros less per pole, wich is not neglectable.
Offline Michael4
#8 Posted : 09 February 2017 23:22:31(UTC)
Michael4
Correct me if I am wrong but doesn't the extra height of M track limit the choice of catenary masts?
#9 Posted : 10 February 2017 00:14:36(UTC)
There's not much difference in height between M track and C track.
Offline MKOpSeattle
#10 Posted : 17 September 2018 08:26:13(UTC)
MKOpSeattle
I find myself in similar situation with lots of M-track, except that I also have catenary masts and wires for M-track. I really like the looks of the new Marklin wires. I'm willing to let go of the old M-track masts and wires. But I also like the flexibility of the M-track clip-on masts. I have the Sommerfeldt catalog and all the masts are bolted onto the base board. Is there any way to have clip-on masts and new thin wires from Marklin or Sommerfeldt? Maybe another manufacturer? Thanks.
Offline mvd71
#11 Posted : 17 September 2018 09:54:02(UTC)
Views messages in topic : 1,951
I'm pretty sure in the past I clipped the new style mast onto m track using the c track clips. It was a little bit tight, but it will work as I recall.
I'll try to find a spare mast to check
This page was generated in 0.453 seconds.
