Offline efel
#1 Posted : 30 January 2017 15:44:57(UTC)
efel
Using servo instead of solenoid motors in C track turnout requires precise positionning of the servo under the basement.
Here is a solution that avoids that difficulty: it consists in fixing the servo directly on the turnout. That necessitates a rather big hole in the basement, but does not require any precision. Furthermore, that hole is smaller that the one many modelists make for fixing the standard solenoid motor, leaving the point in place.
If necessary, the servo can be removed for fixing:
Fred
thanks 12 users liked this useful post by efel
#2 Posted : 30 January 2017 16:49:34(UTC)
So, as I see it, you have mounted the motor on the plastic cover of the point mechanism, is that correct?
How well does it work, i have wondered about doing a similar thing myself.
Offline efel
#3 Posted : 31 January 2017 11:27:24(UTC)
efel
Yes
That works perfectly, but, as it's new, I can't say anything about reliabilty. I guess it's at least as reliable as the mounting under the basement which is very often used.
Fred
Offline rbw993
#4 Posted : 31 January 2017 13:59:43(UTC)
rbw993
Hi Fred,
Who makes these servos and what do you use to control them, M84 decoders?
Roger
#5 Posted : 31 January 2017 15:10:22(UTC)
That looks like an excellent idea!
That looks exactly like what I should do to replace a number of failing Märklin motors in my hidden station area!
Do I see it right that you have preserved the spring loaded action of the blade so that points can still be taken backwards without being set?
#6 Posted : 31 January 2017 15:58:42(UTC)
Hi Fred,
Roger
The servos are small radio control servos. ESU market them along with a decoder/controller, and I have a feeling uhlenbrock do too.
The r/c servos are also available on eBay, and several other decoder manufacturers make decoders that will drive them.
One advantage of using such servos is that you can set the limits of motion for the servo arm, and the speed of operation by setting up the registers in the decoder. Great if you are using servos for things like crossing gates, or semaphore signals where you can have the arm give a little bounce to simulate the slack in the point rodding.
Offline efel
#7 Posted : 31 January 2017 20:17:34(UTC)
efel
Hi Fred,
Roger
Hi Roger,
Any RC modelism shop sells such servos. Also ESU, Uhlenbrock and others.
To drive servos, I personnally use ESU Switchpilot Servo, controlled with an intellibox.
Fred
thanks 1 user liked this useful post by efel
Offline efel
#8 Posted : 31 January 2017 20:32:30(UTC)
efel
Hi Jacques,
Presently, the link between the servo and the turnout is a 0.5mm piano wire, and the spring effect is too strong. I'll make some trials with 0.4 or 0.3 mm piano wire in order to improve that function.
Fred
#9 Posted : 03 February 2017 00:31:10(UTC)
Hi Fred,
Roger
Servo's have a 3 wire connection (Brown red orange, or black white red, typically), and their own signals - PWM (pulse width modulation).
The way PWM works is you have a period of signal time and the % of that signal period the signal is high, vs the time it spends low (duty cycle), determines the degree of rotation the servo is presently in.
So _|-----|___________ is one angle
and _|--------------------|_ is a much further angle.
The range through which the servo can rotate (its not 360 degrees necessarily, typically its 180 degrees) is servo dependent.
The changing of that high time vs low time signal ratio determines how fast the servo prepositions.
So a servo controller is required - something that can repeatedly feed a square wave signal with varying high and low levels that can be changed on the fly easily.
Servo decoders are the ideal solution.
Offline efel
#10 Posted : 07 February 2017 17:45:04(UTC)
efel
Hi Jacques,
Fred
With a 0.25 mm piano wire, the spring effect is roughly the same as the original one (i.e.without motor or with marklin motor).
I think that a 0.3 or 0.35 mm should also work
Fred.
Online GlennM
#11 Posted : 07 January 2025 03:12:08(UTC)
GlennM
Just curious if there was any update on this subject with regard to reliability and best piano wire to consider using.
I recently saw a 3D printed solution on Facebook but sadly did not take down any details, but the fixing attaches to the C-track and the motor then attaches to the fixing so it acts as a go between to control the movement of the switch.
Does anyone have any other updated solutions for fixing servo motors to C-track to make them more reliable?
Offline BenPerr
#12 Posted : 13 April 2025 06:21:50(UTC)
BenPerr
Designed my own servo driver for the turnouts - works for both straight and curved one, but need a 3D printer to print them.
They fit on the existing Marklin solenoid attachment and I wanted the servo horizontal to minimize the depth taken from the layer below.
I did run 1K cycle on it and worked OK.
If there's interest, I am OK sharing the STP and STL.
thanks 5 users liked this useful post by BenPerr
#13 Posted : 13 April 2025 11:49:51(UTC)
I don't know about reliability, but there are quite a number of examples of servo mounts for C track on Printables and Thingiverse available for 3D printing. Some are duplicated across both sites.
Offline CryptoCoach
#14 Posted : 28 June 2025 04:23:55(UTC)
CryptoCoach
United Arab Emirates
This is very cool. Since you offered to share the Print File I would highly appreciate this files.
Thanks you very much in advance and
best regards and greetings
Carsten
Carsten
Crypto and CashFlow Coach
Märklin Collector
Looking for Scale 0, H0 / 00 from 1935 till 80´
Offline applor
#15 Posted : 29 June 2025 04:41:50(UTC)
applor
+1 for ESU, the Switchpilot Servo 3 lets you control 8 servos which is fantastic price/unit.
Online GlennM
#16 Posted : 29 June 2025 05:58:01(UTC)
GlennM
Hello, they look great ThumpUp ThumpUp
I would be very interested in the files if you would be willing to share
Online GlennM
#17 Posted : 29 June 2025 06:01:52(UTC)
GlennM
Thanks Alan I will have a look
#18 Posted : 29 June 2025 21:41:18(UTC)
As would I please!
Offline rschaffr
#19 Posted : 30 June 2025 16:44:10(UTC)
rschaffr
I have used servos for opening and closing the doors to my lok shed, but they are generally light duty and have had failures. For switching when I want to hide the motor/solenoid actuator I use Circuitron "Tortoise" motors with the Marklin under board mount adapter.
-Ron
thanks 2 users liked this useful post by rschaffr
Offline Kiko
#20 Posted : 01 July 2025 03:23:25(UTC)
Kiko
Some years ago I also switched from using servos for turnout control to Tortoises. I find the Tortoises to be very reliable with no failures and positive turnout closing. Servos are nice for lots of other railroad related animations. I use them for crossing gates, roundhouse doors, water spouts, etc. -- they work very well for these applications.
Andry
Andry
Online GlennM
#21 Posted : 01 July 2025 09:37:08(UTC)
GlennM
I was not aware that Marklin did an under board adaptor for C track. Do you have a reference number for this?
Offline marklin61
#22 Posted : 02 July 2025 13:03:03(UTC)
marklin61
The under board adapter shown is for K track, and I have used these extensively with servos. Marklin do not manufacture an under board adaptor for C track as the decoder and switch mechanism is already hidden beneath the plastic housing.
Steve...............
Life with Pinot Noir, Chocolate and Marklin trains..........
thanks 1 user liked this useful post by marklin61
#23 Posted : 02 July 2025 16:13:27(UTC)
I don't like the Tortoise switch motors, they are LARGE (the picture shows around full size on my 16" screen, YMMV), and they are expensive, last price i saw was around GBP40 each. We have them on a couple of club layouts and I have found them a pain to get aligned correctly so the points throw properly. Agreed some of this is not the fault of the tortoise motor itself, but the way it mounts gives minimal, if any, throw adjustment.
Online GlennM
#24 Posted : 03 July 2025 02:56:52(UTC)
GlennM
Yes, that is what I thought.
Offline BenPerr
#25 Posted : 03 July 2025 04:14:11(UTC)
BenPerr
Here is a link to the STL files for the Horizontal Servo adaptor.
Let me know if you have any questions.
https://www.thingiverse.com/thing:7081684
thanks 1 user liked this useful post by BenPerr
Offline Kiko
#26 Posted : 03 July 2025 04:31:14(UTC)
Kiko
Hello KiwiAlan,
Speaking from years of personal experience, I must respectfully disagree. Yes, the Tortoise switch motors are large (compared to a servo), but I never had any issues finding room for them under the plywood sub-board. I have over 50 of these on my layout and never have any issues with reliability. I've mounted some of my Tortoises more than 12 inches from a turnout with excellent reliability. Using tiny piano wires provides many options in mounting positions.
As for "expensive" -- I purchased mine here in Canada for about CDN$25 ea. This is more expensive than cheap servos, but on par with Marklin switches.
Again, from personal experience, I've never had any throw adjustment problems. I found that with the vertical slider on the Tortoise, there's plenty of room for precise adjustment. The stall motor is excellent in terms of holding the turnout in the selected position -- I've never had derailments due to flaky turnout alignment. It's always a solid contact and with piano wires, you can adjust tension to various levels.
Just my 2 (Canadian) cents on this topic (not worth much these days...).
Andry
Andry
Guest (12)
This page was generated in 0.717 seconds.
