#1 Posted : 28 January 2017 13:32:34(UTC)
ESU 2017 new items
>DOWNLOAD PDF<
New E03 Electric and Ludmilla.
Offline MaerklinLife
#2 Posted : 28 January 2017 15:58:24(UTC)
MaerklinLife
Anybody know what internal upgrades they've made to the new ECoS (besides the new power supply) and what it means if one is considering buying one?
#3 Posted : 28 January 2017 17:10:25(UTC)
Internal upgrades means change inside of the central station.
Not sure if they change the body too.
The new catalog number 50210 says anyway new central station.
Let´s see when it arrives out.
#4 Posted : 28 January 2017 17:43:15(UTC)
MaerklinLife
Thanks, but no real answer. I am perfectly aware what internal updates mean, I am not sure what changes they've made. Besides a new power supply.
The system seems to be pretty stable anyway, so perhaps no real change is needed for the ECoS to follow suit. Personally, I think ESU is doing the right thing by developing on something they've already got instead of reinventing the wheel both hardware and software wise.
The real deal is the LokPilot MKL which allows for putting ESU decoders into ealier Märklin locomotives. Finally ESU caved in and made this version! This means that I can start changing decoders in these models and implement the ABC braking system in my layout.
#5 Posted : 28 January 2017 17:57:51(UTC)
The new decoder cannot be used for many early Märklin mfx locos where the decoder has a blue PCB - the regular ESU decoders can be used.
For locos where the decoder has a green or red PCB you must check carefully whether the MKL version or the regular version can be used.
#6 Posted : 28 January 2017 18:05:58(UTC)
MaerklinLife
Thanks. The main thing here is that: Now I have real options. Smile
The problem of course is: can we trust the colours as our only way of identifying the type of decoder? I would not count on it.
#7 Posted : 28 January 2017 18:14:42(UTC)
So far you can rely that blue PCB stands for ESU decoder and ESU decoders so far were NEM compatible.
Red or green are Märklin decoders and can be NEM compatible or NMRA compatible. Take the magnifying glass and check whether AUX3/4 are amplified on the decoder.
An incomplete list of Märklin locos that require NEM compatible decoders can be found in the manual of the 60940 MSD Spezial.
#8 Posted : 28 January 2017 20:39:46(UTC)
MaerklinLife
The "problem" also lies with the Trix Traxx back from 2008. Those models also does not work with ESU 21-pin decoders. I had to install mld's in my converted versions them to make them work. I don't know if Märklin has changed the PCB in the re-release from last year. But later editions of Märklin locos seem to follow the NEM-standard.
I am happy that I can now start to rely on one manufacturer only. I hate having too many different decoders. Although it worked fine with the mld (1 and 3). They are fine decoders, I am just used to tuning the ESU ones. It is of course a matter of personal taste. Some how I have less tuning problems with the ESU decoders.
#9 Posted : 28 January 2017 21:18:31(UTC)
I don't think so, but I do not have statistics.
The MSD/3 has CVs that allow to make it NEM compatible, but the factory default is NMRA compatible.
The Trix TRAXX requires amplified AUX3/4 while AUX1/2 are not used.
The Trix BR 216 uses AUX1/2 while AUX3/4 are nor used, thus allowing any decoder in that loco.
I did not examine my plastic body Märklin TRAXX yet.
Some Märklin locos with 21MTC socket require NEM compatible decoders, some require NMRA compatible decoders, for some locos both types can be used.
And now back on topic: theoretically ESU should now have suitable decoders for all Märklin locos with 21MTC socket.
But finding the correct decoder can be tricky - and IMHO "earlier" and "later" do not help choosing the right decoder.
#10 Posted : 29 January 2017 09:10:13(UTC)
Of course does my answer is correct and real.
I´m pretty sure they present new design of the Ecos.
#11 Posted : 29 January 2017 15:00:19(UTC)
I suspect the internal changes include a faster quad core processor like the cs3 ...
This page was generated in 0.471 seconds.
