Offline wbrown527
#1 Posted : 26 January 2017 17:55:26(UTC)
wbrown527
I have a Marklin 3355 which does not run. Several wires were disconnected from the electronic module. Does any one have a picture of how the wires should be attached?
Bill
#2 Posted : 26 January 2017 18:40:06(UTC)
I have no 3355 but I have other loco with one same as your?
Offline wbrown527
#3 Posted : 26 January 2017 23:10:52(UTC)
wbrown527
Thanks for the photo. Unfortunately, my electronic reverse is different. I will attempt to take a photo for everyone's perusal
Bill
Offline wbrown527
#4 Posted : 26 January 2017 23:35:08(UTC)
wbrown527
Thanks for the photo. Unfortunately, my electronic reverse is different. I have attached some photos. Apparently, very few engines used this unit. According to my Marklin parts catalog, only 3355 and 3360 share the reverseDSC05976.JPGDSC05977.JPGDSC05978.JPGDSC05980.JPGDSC05979.JPG
Bill
#5 Posted : 26 January 2017 23:53:47(UTC)
I can tell you that Märklin 3308 (Steam loco BR 85) also had this reverse unit, unfortunately my 3308 became digital 20 years ago or so, so I don't know how the original wiring was... Unsure
Basically it is a rectifier so the relay gets DC voltage and switches silently instead of jumping and making noise & bright lights...
There is a small wiring diagram in the spare part sheet for 3355 ...
#6 Posted : 26 January 2017 23:56:36(UTC)
Bill
The electronics is not a reverse unit - that is the solenoid device on the right of the photo that determines which direction the motor runs.
The electronic board i suspect is for constant brightness headlamps.
Offline ixldoc
#7 Posted : 27 January 2017 06:31:54(UTC)
ixldoc
Hi Bill,
The blue wire resting on the chassis looks very sus to me ? worth checking if it is not broken.
I know I have one of these units but I will have to look hard to find it.
Howard.
#8 Posted : 27 January 2017 08:40:59(UTC)
I can see a brown wire with a lose end, but cannot see where the other end goes to. Is it off the PCB or off the loco frame?
I see a blue wire that is badly squeezed. If loco only runs in one direction, check that blue wire.
The PCB disconnects the motor from the reversing voltage to allow reversing without a jump.
Some locos also have low voltage lamps - the low voltage also comes from this PCB. I could be wrong but I think the 3355 has standard light bulbs (19 V type).
Offline ktsolias
#9 Posted : 27 January 2017 09:38:38(UTC)
ktsolias
Hi bill
Here there are one picture of an electronic reverse unit from my 3309, but there are TELEX couplers as well:
And a drawing of this module with the connections:
And finally the plan from the 3355 spare parts drawing:
May be you will find them helpful
Costas
This page was generated in 0.464 seconds.
