Joined: 29/05/2014(UTC) Posts: 839 Location: DONEGAL, CARNDONAGH
Hi guys, Im building a 3600 rail layout with 2 circuits .All points are on inner circuit with 1 pair joining the two .I had everything hooked up and wanted to test.I powered up a transformer and all the lights on points lit up, but as soon as turned up the power all lights dimmed and then went out amd loco would not work. So I have started the wiring again but am not sure about the level crossing.Its like the 7192 but with solid rail.Each side has a yellow wire coming from it and a plug in connection.I was looking at diagram on the Forum and it seemed to show both loose wires joined together and from one of the plug in connections a wire going to the l connector on transformer. Would this be right. Im using 2 6647 transformers Eddie
Joined: 18/11/2008(UTC) Posts: 495 Location: Oakville, Ontario
The two yellow wires are for the solenoids that raise the gates, they are connected to the L of the transformer either together, separately or via a distribution block like 72090 (formerly 7209). The ground is through the tabs at the centre of the roadway. Here is a wiring diagram I found on the internet, they connect on side of the roadway to the outlet on the other, but the yellow is common:  Hope this helps! Harold.
 3 users liked this useful post by Crazy Harry
Thanks Harold. That explains it perfectly. Eddie
Joined: 21/10/2004(UTC) Posts: 31,704 Location: United Kingdom
I have the 7192 and it working fine as Crazyharry show image.
Do you have a manual with your 7192? I do have it - let me know So I can photos the manual. |
Hi Steven, I dont have a manual for it.
Joined: 14/01/2006(UTC) Posts: 1,802 Location: Wurttemberg
 2 users liked this useful post by Markus Schild
