Offline MalinAC
#1 Posted : 26 January 2017 16:02:39(UTC)
MalinAC
Ireland
Hi guys, Im building a 3600 rail layout with 2 circuits .All points are on inner circuit with 1 pair joining the two .I had everything hooked up and wanted to test.I powered up a transformer and all the lights on points lit up, but as soon as turned up the power all lights dimmed and then went out amd loco would not work. So I have started the wiring again but am not sure about the level crossing.Its like the 7192 but with solid rail.Each side has a yellow wire coming from it and a plug in connection.I was looking at diagram on the Forum and it seemed to show both loose wires joined together and from one of the plug in connections a wire going to the l connector on transformer. Would this be right. Im using 2 6647 transformers Eddie
Offline Crazy Harry
#2 Posted : 26 January 2017 19:02:23(UTC)
Crazy Harry
The two yellow wires are for the solenoids that raise the gates, they are connected to the L of the transformer either together, separately or via a distribution block like 72090 (formerly 7209).
The ground is through the tabs at the centre of the roadway.
Here is a wiring diagram I found on the internet, they connect on side of the roadway to the outlet on the other, but the yellow is common:
Hope this helps!
Harold.
thanks 3 users liked this useful post by Crazy Harry
Offline MalinAC
#3 Posted : 26 January 2017 19:52:41(UTC)
MalinAC
Ireland
Thanks Harold. That explains it perfectly. Eddie
#4 Posted : 26 January 2017 22:25:31(UTC)
I have the 7192 and it working fine as Crazyharry show image.
Do you have a manual with your 7192? I do have it - let me know So I can photos the manual.
Offline MalinAC
#5 Posted : 27 January 2017 08:46:43(UTC)
MalinAC
Ireland
Hi Steven, I dont have a manual for it.
Offline Markus Schild
#6 Posted : 27 January 2017 11:13:22(UTC)
Markus Schild
Hi Malin,
This is the manual:
https://dl.dropbox.com/s...192-68709-on-0269-ka.pdf
Markus
Offline MalinAC
#7 Posted : 27 January 2017 15:21:33(UTC)
MalinAC
Ireland
Thank you kindly Markus
This page was generated in 0.478 seconds.
