Offline magload
#1 Posted : 16 January 2017 19:52:01(UTC)
magload
My CS2 would not calibrate. I used the mouse and got to the calibration screen but touching the cross hairs would not register. The first one would register after many attempts. I was in a real panic as the warranty ran out last month ( 16 days ago).
I called the Marklin customer service number here in Germany . The service rep told me this was a common issues and the technicians suggested vacuuming or using dust off on all of the openings. She said that the vast majority of returned units with faulty touch pads were repaired by cleaning dust out of the unit.
The vacuum cleaner did the trick. Several minutes of vacuuming did the trick. What a relief!!!
Hope this info helps others.
thanks 3 users liked this useful post by magload
#2 Posted : 16 January 2017 19:56:57(UTC)
We already have a thread about the dangers of eating crisps in the train room. This problem is known, but your post may help others.
Offline dickinsonj
#3 Posted : 20 January 2017 01:25:18(UTC)
BigGrin
Keep that screen clean and if you have fat fingers like mine just use a stylus to interact with your CS2. Or better yet just use a mouse to control the CS2 - that is a huge improvement and it is very easy to do.
This page was generated in 0.333 seconds.
