Offline Carlos
#1 Posted : 17 January 2017 03:26:26(UTC)
Carlos
Hello to Everybody
Please I need to know which is the best way to cut a C track.
Thank in advance, my best regards,
Carlos
Offline baggio
#2 Posted : 17 January 2017 03:33:05(UTC)
baggio
Is it REALLY necessary to cut the track?
Can you not use small pieces?
Offline TEEWolf
#3 Posted : 17 January 2017 04:55:20(UTC)
Originally Posted by: Carlos Go to Quoted Post
Hello to Everybody
Carlos
Why do want to cut them? I agree with baggio.
For your support building a layout with c-tracks: I add the following PDF files.
I hope these files makes your "cutting crew" needless. Huh BigGrin
Offline baggio
#4 Posted : 17 January 2017 05:05:19(UTC)
baggio
The two charts are a bit of a mouthful, however.
What I do, is just lay down the track, have plenty of small pieces of different sizes handy and play around with the layout.
Often enough by squeezing a bit, you get the tracks to join and stay joined. ThumpUp
If that does not work, I once went to Mike's who added up the distance I needed covered and after some adding and subtracting ( track no. 172 = 172 mm and track no. 188 = 188 mm) and doing the same with small pieces, Mike got the size I needed without cutting anything. BigGrin
Try it before you cut.
#5 Posted : 17 January 2017 12:20:27(UTC)
I agree with my previous speakers. However, in case you insist: I used this saw to obtain a straight cut.
And I used K track connectors to fix the resulting mess.
Offline michelvr
#6 Posted : 17 January 2017 15:10:36(UTC)
michelvr
Hello Carlos,
Here's a question I can answer with confidence!
The best way to cut C track is with a Double-Bevel Compound Miter Saw.
But first be warned! This is a dangerous task and can cause bodily harm. Safety first! If you are not sure please be humble enough to know and not proceed.
Below is the procedure in which I had perfect results. Doing it any other way may result in broken C tracks or injury.
Always clamp the C track on it's base and cut through the tracks into the molded plastic base.
I sometimes had a piece of wood added to the top to help in securing the track if the piece to be cut was short.
The trick is to use a fine crosscut carbide blade. Go slow and gently when you cut the track.
It works like a charm!
Michel
#7 Posted : 17 January 2017 20:40:23(UTC)
To start, I've not had reason to cut c-track (yet).
Assuming you need to cut to shorten, the Märklin guidelines are to remove a segment from the middle, so the shorter piece still has the factory ends on it - so it takes 2 cuts to cut out the amount you need to remove.
Then you jumper the electrics below from one end to the other via the contacts below.
A good fine blade is the best to use.
Screwing down the track to a section of wood and then cutting through the track and plastic base and into the wood slightly is also a good idea, as the track should not move(much) during cutting.
I'd then glue the two ends together after temp fixing them (to ensure track alignment) and apply super glue to the plastic ends (assuming they are burr free and smooth) to fix the two sides. Verify transition is smooth. Then use an epoxy like JBWeld or Patex to permanently and strongly combine the two halves using the underside of the trackbed.
Offline ixldoc
#8 Posted : 18 January 2017 00:49:32(UTC)
ixldoc
I have had occasion to cut a. just the track and b. the entire piece of track.
For the former I use the following setup with a thin cutting disc. I cut two pieces this way about 4 stud lengths from the end then join the tracks. This forms a short detector track with the marklin spade connectors available under the track for the contact wire.
This gives a nice fine cut which can be controlled so as not to cut the plastic bed.( the cut is just visible to the right of the shadow on the track).
For the latter I have used a drop saw with a cutting disc but care must be taken not to overheat the plastic. I have also used a fine bladed hacksaw as shown. I found the track wrecked my balsa saw in short order. I usually screw the track down via the Marklin provided screw points. Once cut I fine tune the end with a facing sander.
I had to sort out this method to cut precise track ends on my transfer table project.
Howard.
thanks 8 users liked this useful post by ixldoc
#9 Posted : 18 January 2017 04:00:09(UTC)
I used a similar technique to Howard on my K-tracks. See http://layout.mixmox.com...20020106Ktrackcuttingjig
Offline Carlos
#10 Posted : 19 January 2017 01:36:23(UTC)
Carlos
No because a track of exactly 2 inches
Carlos
Offline Carlos
#11 Posted : 19 January 2017 01:38:30(UTC)
Carlos
Hello to Everybody
Carlos
The reason is a need to insert in a special place a track of exactly 2 inches
Carlos
Offline baggio
#12 Posted : 19 January 2017 03:03:25(UTC)
baggio
Hi, Carlos:
Cut the tracks if you are so inclined, but you may want to try to substitute longer/shorter pieces along the layout if possible.
Perhaps you could put 24188 (188.3 mm) straight pieces in place of 24172 (171.7 mm) pieces or vice versa.
This way you may be able to use a short straight piece - 24064 (64.3 mm) for example.
Also sometimes, lifting the track and forcing it gently in will work as well if the overlap is very small.
I would try the above before cutting.
My usual 2 cents' worth.
Silvano
#13 Posted : 19 January 2017 13:22:49(UTC)
What forum member LeoArietis did:
Source:
http://www.svensktmjforu...0990.msg119715#msg119715
This page was generated in 0.674 seconds.
