Offline MalinAC
#1 Posted : 11 January 2017 16:59:42(UTC)
MalinAC
Ireland
Hi guys, Im going to try and build a solid centre rail track layout and I need some help with the wiring. Is there a Marklin book that shows how to wire up the different parts of the layout and if so whats the part number.Im using 3600 track. I would appreciate any help as I want to find out what all the different track pieces do and how to wire them up .Eddie
#2 Posted : 11 January 2017 20:01:51(UTC)
Try here Eddie... http://www.lctm.info/Sec...lioteca/Libros/index.php
The old 0753 and 0763 books should help. They are in German but the pictures are not BigGrin
Offline Markus Schild
#3 Posted : 11 January 2017 23:35:46(UTC)
Markus Schild
Hi Eddie,
Generally you must differ the switches and signals before and after 1952/53. Until 1952 switches and signals have two wires: One for the light (yellow) and one for switching (black). The rail is ground. Every time the switch - wire is switched to 20V the signal or the switch changes its position. These components can't be switched to a defined position, they just change with every pulse. The switch-panels just have one bottom and are connected to 20V. From 1952/53 the system which is know until today was introduced: The electro-magnetic devices have three wires: Left - right (red/green) and yellow. The rail is just the ground for the light. The devices were connected to switch-boards with two bottoms which are connected to ground. These device can be switched to a defined position.
Markus
3600 track plans for post-war historic/dealer square-shaped layout (Collector's Corner general)
by Marklinista 24/09/2017 05:28:29(UTC)
3600 Track. (Collector's Corner general)
by Ian555 17/07/2013 10:01:17(UTC)
3600 TRACK Radius options ? (Collector's Corner general)
by 20-VOLT-AC 03/03/2012 13:59:12(UTC)
This page was generated in 0.231 seconds.
