Offline Armando
#1 Posted : 07 January 2017 23:38:09(UTC)
Armando
Hello all!
I'd like to share with you this strange behavior that I am noticing on my new Insider BR 95 Locomotive, 39095.
I installed the enclosed smoke generator. When it is turned on, its stem glows smoldering red! The smoke seems to generate without any problem. However, I had never experienced such an issue with any of my steam locomotives. Just to double-check on the matter, I exchanged the initial smoke generator for a new one and inserted it back into the locomotive. Still the same behavior...Confused
And by the way, the glow is not a reflection from the headlights. I tested with lights on and off. Same thing.
Is anyone experiencing the same situation?
Armando García
Offline skeeterbuck
#2 Posted : 09 January 2017 15:04:47(UTC)
skeeterbuck
WOW Armando! OhMyGod Scared
I've never seen a Seuthe unit working like that. I would stop using the engine and check with Marklin and Seuthe to find out what the problem may be. Be sure to include that pic of the unit in operation with you inquiry.
In the past, I have applied more voltage to a unit just to test it's operation (i.e. 18 volts to a unit rated for 14 volts) but I've never seen one get that hot to cause glowing.
Good luck and let us know what they have to say.
Chuck
thanks 1 user liked this useful post by skeeterbuck
#3 Posted : 09 January 2017 16:01:52(UTC)
This probably happens because there is no more/ not enough smoke fluid in the generator!!
The good news is that you probably have a very good generator producing **lots** of smoke, but maybe not for very long.
And it may break down quite rapidly too
Running it "dry" is not a good idea IMHO.
Seuthe smoke generators have consistently exhibited wide variations in performance and durability.
Cheeers
Offline Armando
#4 Posted : 09 January 2017 18:58:35(UTC)
Armando
Chuck
Chuck,
I've already written to the Märklin Customer Service and forwarded the picture too. Will post their explanation - if any - as soon as I get it.
Thanks!
Armando García
Offline Armando
#5 Posted : 09 January 2017 19:01:56(UTC)
Armando
Cheeers
Salut Jacques !
The smoke generator did contain smoke fluid, as you can see from the picture. What seems to help - a little bit - is to set the function on the CS2 to option "smoke". Will test it again with more fluid, maybe half way up filled- and see if it helps.
Armando García
Offline jlopez
#6 Posted : 05 October 2018 02:18:19(UTC)
jlopez
Just had this happen after i took the body of a loc to service it. I’ve never seen this happen before. I’ve ran engines with the smoke generator dry and this is not normal. I did use fine metal tweezers to push it down. I think it may have scraped something off the “wick”. Just ordered a new one and hope that solves the problem.
Did marklin ever write back?
Jlo
Offline Drongo
#7 Posted : 05 October 2018 12:08:00(UTC)
Drongo
Jlo
Right, and pigs fly.
#8 Posted : 05 October 2018 13:30:31(UTC)
Hi Armando
Obviously, the Seuthe resistor is too low which produces more heat and the glowing.
The down side is that it puts your decoder at risk.
I believe the Seuthe resistance should be around 100 Ohms or higher to be compatible with the max current of the decoder (250mA) under digital power @18V (no lower than 72 Ohm to be exact)
Sorry to be technical but the impact of burning the decoder is at least 3 months wait, possible damage to your loco and its packing unless you have a very good dealer who accepts to exchange the Seuthe unit w/o discussions
So my advice is to measure the Seuthe resistance and if lower than 100 Ohm I would remove it until Märklin answers.
This page was generated in 0.345 seconds.
