Offline ec2808
#1 Posted : 18 December 2016 08:12:31(UTC)
ec2808
Indonesia
I have problem with 39552
When I put on the track and using MS 60657 and it only show function : Lights, Smoke, Direct Control.
While in the manual it have many function and sound.
Anybody have advice or similar problem with me ?
#2 Posted : 18 December 2016 08:19:17(UTC)
There is two of them.
39552 with the sounds
39553 without the sounds
Are you sure you did read correct the catalog number of the locomotive?
It´s not the 39553 you have?
Offline ec2808
#3 Posted : 18 December 2016 08:31:45(UTC)
ec2808
Indonesia
Yes I am sure it was 39552, unless Marklin gave the wrong items, since it was fresh from the factory.
Offline ec2808
#4 Posted : 18 December 2016 08:34:54(UTC)
ec2808
Indonesia
How to check it was 39552 or 39553 ?
#5 Posted : 18 December 2016 08:36:44(UTC)
Using mfx, the MS2 (60657 is MS2) just shows the functions the decoder reports.
Maybe it's a non-sound loco in a "sound box".
Bought on eBay?
Read the description carefully. Maybe someone wanted two locos with sound and different running numbers ...
Is there a speaker inside the loco?
A CS2 will show the ref. number of the loco.
#6 Posted : 18 December 2016 09:37:00(UTC)
39552 with the speaker
39553 without the speaker
Open the body of the tender and check if there is the speaker.
#7 Posted : 18 December 2016 10:32:13(UTC)
It might be swap wrong loco at shop?
Check the running number on cab side?
39552 - 57 579
39553 - 57 584
This page was generated in 0.439 seconds.
