Offline baggio
#1 Posted : 13 December 2016 14:06:40(UTC)
baggio
Hello, Everyone:
In my never-ending quest to get Marklin locos to speed up, I am considering tinkering with the CV parameters of the locos so as to change the ratio between pulling power and speed.
The idea would be that the loco would be able to pull fewer wagons but go at a faster speed. BigGrin ThumpUp
Any thoughts as to whether this could work?
Thanks.
Silvano
Offline Thewolf
#2 Posted : 13 December 2016 14:49:00(UTC)
Thewolf
Hi BGGIO BigGrin
To replace your engines marklin by turbo engines in 1/87 ??Flapper Flapper Blushing Woot Woot
I know that you like....speed Scared Scared
My day's joke
Thewolf
#3 Posted : 13 December 2016 16:07:04(UTC)
Except for some C Sine locos, Märklin's factory setting will be maximum speed. Changing CVs can hardly make locos faster than Märklin's factory default settings.
There could be exceptions where you can gain a little bit of extra speed by fiddling with the load regulation CVs. You shouldn't try this if an MS2 is the best controller you have because you cannot read the factory default settings.
More promising approaches: increase the track voltage (will reduce motor longevity) or change the gears.
This page was generated in 0.244 seconds.
