Offline Jaime
#1 Posted : 12 December 2016 01:26:24(UTC)
Jaime
Chile
I´m a new member from Chile. A marklin fun in H0, but my new project is a garden layout, a raised roadbed system. I want to use marklin 1:32 and maybe other brands material. For now my choose is track power, stainless steel. My question: Someone has seen or used marklin 1 locomotive in sunset valley track (SS flex track 6 ft ) or another track in code 250?. I have discarded code 332 (like LGB track), it is oversized for marklin 1.
Thanks for your help..
Jaime
#2 Posted : 12 December 2016 10:52:25(UTC)
Stainless steel track is probably best for use outside, although the Marklin stainless steel track does have issues with power conductance which is caused by the track joints. The track clips that Marklin sell don't help all that much. In fact manufacturers such as KM-1 recommend that you do not use the stainless steel track with their KM-1 locos, especially the large, heavy steam locos. The KM-1's can draw serious amounts of current, and if the track doesn't conduct all that well it can lead to boosters not detecting shorts but rather they keep on trying to deliver more power. I know this from experience, having had the pickup wiring in my KM-1 loco burn out due to this very problem.
KM-1 have their own track, and Marklin also sell the track previously made by Hubner. Peco also make and sell G1 track. All of these track types contain a percentage of nickel which helps in conductivity but may not last that well if used outside.
KM-1 track: http://www.km-1.de/html/gleise.html
Peco track: http://www.hattons.co.uk...32_Scale_/spec_list.aspx
Marklin / Hubner track: http://www.maerklin.de/e...ucts/gauge-1/railtracks/
#3 Posted : 12 December 2016 12:43:37(UTC)
On a related note.. I wonder how durable that plastic road bed is when it is used outside.. Do you know of anyone who has used this track outside in a sunny (i.e. high UV) climate - Mid to northern Australia or maybe California or Florida?
Offline Jaime
#4 Posted : 12 December 2016 17:59:14(UTC)
Jaime
Chile
Ok. Apparently the ideal for exterior is stainless steel, although of lower conductivity than brass, does not rust. That could be corrected with more feeders.
Sunset valley track has stainless steel, lots of switches, but I still can not find anyone using marklin on those tracks. They are code 250. On youtube I have seen Peco and Tenmille. I just saw the page of KM 1, very beautiful and apparently recommended for outdoor (have UV stabilizer), but at a higher cost, although I must see the German translator better. I imagine they are code 200, which I think would leave me out of the way material from other scales.
#5 Posted : 12 December 2016 22:20:20(UTC)
I've had PECO tracks in my garden for more than 10 years now; without any problems.
( Even though I don't have a layout at the moment; I've left my tracks outside. )
The tracks are nickel-silver, so you can solder your wires to them, they do not rust, they only get to look more prototypical brown; so after a winter, you have to polish them a little.
If you destroy too many sleeper-pieces by cutting them wrong, you can buy them from Peco as a spare part.
#6 Posted : 12 December 2016 23:54:05(UTC)
Per, do Peco produce G1 curved track and flex track? There's no reference that I can find on the Hattons website.
I know Andreas at KM1 regards the Peco track as being a bit soft, as big heavy locos can wear it out. However we have been using Peco track on our club modular layout with no issues.
#7 Posted : 13 December 2016 00:06:50(UTC)
I believe the Peco track has a UV resistant plastic for this reason, but I don't know how resistant. It will eventually give up anyway, all plastic, even UV resistant, will eventually decay when exposed to UV, it is just a case of how fast.
Peco have templates available on their website
They also have a list of items available.
#8 Posted : 13 December 2016 00:27:44(UTC)
No curved tracks, only straight/flex and turnouts L+R.
You even have to cut the sleepers on the tracks yourself, to make them fit on the turnouts.
( Like having Märklin 24711; but no 24071. )
If asked PECO if the could do a "transition-piece"; but no. ( They only needed to do the sleepers. )
I've also asked if we could expect them to make a crossing; also no.
And I also asked if I could buy the tracks in 2 or 3 meters; but no.
I don't think a heavy loco can wear the tracks out; but they are not as stiff as Märklin-track.
Offline Jaime
#9 Posted : 13 December 2016 01:35:49(UTC)
Jaime
Chile
Per,
Is necessary a rail bender for Peco flex track?, and you used peco rail joiners, or another system, like the rail clamps?
Jaime
#10 Posted : 13 December 2016 09:30:58(UTC)
Originally Posted by: Jaime Go to Quoted Post
Per,
Jaime
A rail bender is not necessary; but it makes everything easier and nicer.
I usually take the tracks apart, and bend each rail individually.
I've made my own track bender, just an old vice with 3 plastic wheels on:
I use the PECO rail joiners.
Offline Jaime
#11 Posted : 13 December 2016 15:56:08(UTC)
Jaime
Chile
wow, excellent idea!!!
What is your opinion about the peco turnouts, which means "electrofrogs"
thanks..
#12 Posted : 13 December 2016 21:06:01(UTC)
I think they are fine BigGrin
They are radius 10 feet and looks very prototypical to me.
Only small locos needs to have power to the "frog", I have not yet used power on mine.
Offline Jaime
#13 Posted : 23 October 2017 11:48:07(UTC)
Jaime
Chile
Yesterday I finished the track laying.
I want to thank for the help and all the recommendations made by members of the forum
Best regards from Chile
Jaime
thanks 6 users liked this useful post by Jaime
Offline Jaime
#14 Posted : 23 October 2017 11:50:51(UTC)
Jaime
Chile
thanks 9 users liked this useful post by Jaime
#15 Posted : 24 October 2017 12:06:30(UTC)
I recently replaced a length of PECO G1 track on two of our club's modules, because the join in track between the two modules was not so great. Here's a photo of what I replaced.
Note the difference between the new track piece and the old - the old is quite worn down compared to the new.
#16 Posted : 24 October 2017 21:18:46(UTC)
I would really like to see a picture from the side, instead of from above; or an accurate measurement of the height of new vs old tracks.
#17 Posted : 25 October 2017 02:25:03(UTC)
It's not so much a height issue, rather compare the rail to the right with the new piece. The edges have been worn down, and the new track rails have a more square profile.
Showing from the side won't show much, plus I don't have those photos.
#18 Posted : 25 October 2017 12:36:56(UTC)
OK, my understanding / definition of "worn" is that the profile gets lower and lower, or the edges are rounded.
On the top track it looks like the tracks have been damaged / bend during transport, which I don't think the PECO quality should be blamed for.
Also, I would rather have the tracks to be a bit softer than the wheels on my rolling stock, than the opposite.
#19 Posted : 26 October 2017 11:05:22(UTC)
No one is blaming PECO quality, I was just surprised at the difference between the new and older track, and the relative amount of wear on the rail edges.
The problem with the inner track (i.e. top) is that there is a height difference in the rail join, which tends to make locos an wagons leap and rock as they go over it, as this video from 2014 shows. I've packed it up a bit to make it much more even.
The outer track looked like it had been bent at some stage, hence why I replaced it.
#20 Posted : 27 October 2017 21:20:59(UTC)
No one is blaming PECO quality, .............
Well, that wasn't what I meant you did, and I'm not trying to promote PECO. BigGrin
I'm just trying to find out if you have experienced something I haven't seen.
This page was generated in 0.697 seconds.
