Offline ktsolias
#1 Posted : 23 November 2016 10:58:55(UTC)
ktsolias
In a previus post in this forum I show two locomotives that I bought recently
https://www.marklin-user...-2016-Edition#post532251
Are two 3048 who I bought in very poor condition
The 1st is a 3048.2 from 1962 (Box date)
The 2nd is a 3048.5 no box no date but the production was from 1965 till 1968
So we are speaking for 50plus old ladies
Some of you asked to sow the restoration and the results. So we are here
The Original Condition
3048.2
3048.5
Both were not working
So I proceed to disasembling the Locos.
Inside the situation was not very bad
3048.1
3048.5
The motors were stuck and the problem was on the rotor bearings. The original foam where the oil goes was a hard mud and had block the rotor axles.
Very good cleaning of the axles, gears, rotors with isopropyl alcool
Reassembling carefully
A bit of oil
Test run: Running very nice and smooth
The 3048.1 version has the hand lever for changing direction
You can see how its working
The results were very good so far
The covers after removing the smoke deflectors cleaned carefully with a lot of warm water and detergent with a brush.
Last rinse with distilled water and drying.
Photos from the final result will follow
Actually the only think that I did was a good service!!!!!
I have ordered the E188838 motor and ESU magnets t convert them to digital with two different ways and compare the results.
Thanks a lot
Costas
Edited by user 25 January 2017 23:18:16(UTC)  | Reason: Not specified
thanks 15 users liked this useful post by ktsolias
Offline Ross
#2 Posted : 23 November 2016 23:15:18(UTC)
Ross
Hello Costas,
I did a 60904 conversion of similar loco and wrote a small article how I overcame some problems with this conversion.
The 3026 Article
I hope it provides you with some ideas what is required.
Edited by user 01 January 2025 05:31:57(UTC)  | Reason: Link corrected 01-01-2025
Ross
thanks 2 users liked this useful post by Ross
Offline ktsolias
#3 Posted : 24 November 2016 09:31:54(UTC)
ktsolias
Hello Costas,
The article
Thank you Ross for your answer
I know your conversion (as all the others that you have publish so far)
Is an excellent work, very difficult and complicated, but I don't want to go so far.
I want to do something simpler
I will publish my try
Costas
#4 Posted : 24 November 2016 12:21:23(UTC)
Hello Costas,
The article
the conversion brush plate is available as a spare part (30080), all my conversions these days are with smd led's, they take much less room and the same goes with resistors
Offline Torstein
#5 Posted : 24 November 2016 15:47:06(UTC)
Torstein
There many ways to convert 3048 to digital from the most elegant to the simplest. Here is how I have done it on several 3048.
Set 60944 - brush plate nr.1 and 5 pol rotor with 7 teeth.
I cut off the upper left corner of the brush plate incl. half of the screw hole so the plate fit against the left casing and pins on magnet. There are only one screw hole left at the right bottom. No problem, the forces from the motor are not in that direction so one screw and the pins on the magnet will take care of them.
Separate light and smoke.
I use digital bulb E 610080 and solder a wire to each leg, isolate the soldering and drop it into the old bulb socket, connect to decoder.
Then I solder the output wire I want for the smoke unit to the copper plate/ old socket.
Ready to run.
5 pol motor and perfect performance over many years. Easy and simple.
My 2 cent.
Torstein.
thanks 3 users liked this useful post by Torstein
Offline Ross
#6 Posted : 26 November 2016 02:22:25(UTC)
Ross
Hi Costas,
Glad you have read some of my articles. With the information others have provided you should be able to come up with a simple conversion.
Costas
Ross
#7 Posted : 26 November 2016 03:22:47(UTC)
I've converted the original brush plate (60944) by cutting it off at the left hand top corner, cutting away a section and realigning it by super-gluing it together.
This page was generated in 0.415 seconds.
