Offline mb300e4m
#1 Posted : 11 November 2016 14:41:42(UTC)
mb300e4m
How compatible are Marklin Digital locos with other digital systems? Will they run when on a layout that uses a Digitrax digital controller for example? Also will non-Marklin decoders function normally using a Marklin digital controller?
If I am using the wrong terms, please correct me, I have been an analogue guy since late 1940s. I need some basic lessons/tutorials in Digital. Sad
I just acquired a collection of Marklin Digital locos and equipment, it is mostly Insiders Club items and like new. BigGrin
Peter B.
Peter B.
In Sunny Florida most of the time.
Marklin, Trix Express, Trix Twin, Fleischmann, Liliput, Hornby Dublo, and Others, 2 & 3 Rail, AC, DC and Digital, Course Scale Wheels & Fine, 1935 to 1960s usually.
#2 Posted : 11 November 2016 14:51:18(UTC)
The key term is "protocol". Loco decoder and controller should have a protocol in common.
There are protocols like MM, mfx, DCC, SX, DCS.
Märklin locos support MM protocol, some MM+mfx, some MM+DCC, some MM+mfx+DCC. DCC is very rare with Märklin H0 locos, but common with Märklin I locos.
Recent Märklin controllers support MM, DCC, and mfx.
I don't know Digitrax controllers - it's unlikely that Märklin H0 locos will work with them. Check the protocols.
Same for non-Märklin decoders: check the protocols.
#3 Posted : 11 November 2016 15:48:38(UTC)
Early Digitrax controllers supported the early MM protocol, but I don't think they ever supported MM2. It was an option IIRC that had to be turned on in the controller, but I am not aware they continued it on into current controller models.
Assuming that seeing you are talking about digitrax, you have some Loconet devices such as throttles and feedback units then you may like to consider some other control units such as Intellibox (which is a native Loconet device) or EcOS which can have loconet devices attached through an adapter.
Another way to handle Loconet with whatever system you choose is to use a computer program such as JMRI (it is free) to deal with the Loconet side of things. I don't think it can convert Loconet throttle messages to other formats though.
Offline mb300e4m
#4 Posted : 16 November 2016 15:02:34(UTC)
mb300e4m
I e-mailed Digitrax: "I have a Digitrax ZephyrXtra Control system. Is it compatible with any of the Marklin decoder protocols? Is so, can you tell me which ones?"
Here is their answer: "The DCS51 (ZephyrXtra) is compatible with DCC protocols."
Hmmm...
Peter B.
#5 Posted : 16 November 2016 17:31:38(UTC)
remember, you can install DCC decoders into the locos that use a decoder that is unsupported.
Offline mb300e4m
#6 Posted : 16 November 2016 23:07:43(UTC)
mb300e4m
Being a collector who does not modify, that is not an option. I prefer to keep my collection all original if possible, unless original or exact replacement parts are not available. I have used repro parts when originals are not available.
I recently picked up a HAG railcar that had been butchered and is worth very little now. The original motor, trucks, wheels, lights and reverser had been removed, the chassis was cut badly and the trucks had been replaced with 2 Tenshodo power trucks and Kadees. It was a total disaster. But it was cheap and I can use the Tenshodo power trucks in a couple of my double deck trams. The rest is going in the scrap box.
Peter B.
This page was generated in 0.325 seconds.
