Offline MSanches
#1 Posted : 10 November 2016 20:26:54(UTC)
MSanches
When trying to add locomotives I began to have serious difficulties. The decoder was not read or even started reading.
At this point a booster 60174 was connected to CS3.
I tried turning it off and after that I added the locomotives without problem.
I have read some post in this forum about possible incompatibility between CS3 and 60174.
I leave the alert here ... and hope Marklin is aware of these feedbacks.
Regards.
thanks 1 user liked this useful post by MSanches
#2 Posted : 10 November 2016 21:17:44(UTC)
Please do not shout.
If you wish to be helpful may I suggest you address your concerns directly to Marklin at service@maerklin.de
I further suggest you actually provide some substance to your description and problem analysis
- What decoder or decoders
- What firmware version of the decoder(s)
- What CS3
- What software version of the CS3
- What firmware version of the 60174.
- what power supplies (and what CS3 power supply setting)
- whether you were using the main or programming track
- whether there are other devices also connected to the same track output
- what you last did , before you expected the read to occur
- whether the loco/decoder actual is known to work
- have you cleaned the track
- whether you tried manual discovery
and best of all
- is the situation repeatable.
#3 Posted : 11 November 2016 01:05:53(UTC)
I have removed the oversized font in the first post.
The CS3 and 60174 booster are compatible with each other, but there were some issues with boosters caused by the application of one of the CS3 updates.
https://www.marklin-user...indunread-CS3-Plus-60216
This page was generated in 0.338 seconds.
