Offline dietcoke777
#1 Posted : 07 November 2016 13:50:49(UTC)
dietcoke777
Hong Kong
I just got a lovely SBB Danzas 460 train by Rocco and it appears it is impossible to change the decoder address to 78, 72, 60 and 24 using the Marklin IR controller. When I power up the track and hold down the direction change button, the lights start flashing - meaning the loco has gone into programming mode - but the story ends there. The train doesn't run.
The loco only came with a diagram showing pressing a button on the decoder and that's it. No manual available. Does it mean I needed to disassemble the housing to get to the decoder? Is there anyway that I can "make do" with an IR controller without investing in a central or mobile station and still get the 460 running?
Doohhh I am kicking myself, should have bought the Marklin version! Please help!!! Thank you.
#2 Posted : 07 November 2016 14:14:30(UTC)
Some of the older generation of Roco AC locomotives (Re 460) came with a decoder (Uhlenbrock?) which had a button on the decoder which had to be pressed in order to place the locomotive in programming mode. I do not know whether it could then be programmed using a Maerklin IR controller, 6021 or any version of the CS or MS. The locomotive should have come with a separate manual for the digital decoder. If you can't find it, I can scour through my old ones and find the information for you later.
What I did with the one Roco Re 460 in my collection that came with one of these decoders was to swap it out for a Loksound decoder with the standard 8 pin connector. I then downloaded the sound package for the Re 460 from the loksound.eu website and set up the decoder using my Lokprogrammer. If you don't have the programmer, many dealers will program it for you.
Since then, I have modified parameters and added station announcements* using my Lokprogrammer* or 6021 (settings e.g. light intensity).
In the meantime, I found this old post that sounds relevant: https://www.marklin-user...1_Roco-decoder-help.aspx
Offline dietcoke777
#3 Posted : 07 November 2016 14:44:09(UTC)
dietcoke777
Hong Kong
Thank you Mike c.
Would it be correct to assume the housing needs to come off before I can reach that magical programming button?
I found a manual online. I believe the 460 can be programmed with a "central unit" that has a "10-digit keyboard", with an "Off" key, a "direction reversing switch" and a "Function" key. Considering this train is probably as old as I am, what would be the modern day control unit that provides backward compatibility with such a unit?
Thanks again!
PS - I would love to have a Loksound decoder but budget is tight :)
#4 Posted : 07 November 2016 21:47:57(UTC)
Yes - unless you can reach the button with a toothpick.
Most likely it is an older Lenz decoder (MM protocol only, no DCC).
Pressing the programming button might not help if you only have that IR controller.
Maybe get a new decoder and a new controller (e.g. MS2).
Or find someone who can change the address for you.
#5 Posted : 08 November 2016 09:05:20(UTC)
Thank you Mike c.
Thanks again!
A 64610 Decoder (Lokpilot V4.0) would cost 33 EUR (even less with VAT rebate). An older 54610 would be 30 EUR (ETS prices) (Shipping to HK by small packet/lettermail should not cost too much.)
That would enable you to program (enter programming mode) remotely using most standard controllers
If you can't program the OEM one in your Roco model, check with a local shop if they have a 6021 or MS/CS that you can use. Asking a dealer to see how the new technology works with older material is often perceived as an opportunity to try to sell you that technology, so many will allow this. The only thing is you can't do it to many times before they figure out you are not interested.
Offline dietcoke777
#6 Posted : 09 November 2016 14:32:26(UTC)
dietcoke777
Hong Kong
Thank you H0 and Mike C - a fountain of knowledge!
So I managed to lift off the housing and take a look at this: https://photos.google.co...TENsTVNqVmxXdjNYSjdESWhn - it appears the old decoder has been replaced by an ESU decoder by the previous owner already. Can you tell what kind of decoder it is just by looking at it? and can it easily be reprogrammed with 6021/CS/MS?
In terms of changing the train address, what can 6021/MS/CS do that an IR controller (by powering on + holding down the switch direction key) can't?
D777
#7 Posted : 09 November 2016 15:23:32(UTC)
Yes, indeed.
No, I cannot. I think it is a decoder from the V3 generation, but there were several types (DCC only, DCC/MM/SX, MM/mfx).
If it is a decoder with MM protocol then it can be programmed using either of those. But in that case changing the address using the IR controller should also work.
The IR controller can change the address.
Other devices can reset the decoder to factory defaults, adjust acceleration and braking delay, set intensity of headlights, adjust speed curve and maximum speed and some other changes.
If it is a decoder without MM protocol then the IR controller won't do anything with it.
If it is a decoder with MM protocol which is disabled in the decoder then the IR controller won't do anything with it. A 6021 or an MS1 won't help in that case either.
As an optimist, try the address changing sequence a few more times (5+).
Just to be sure: Is there a centre-rail slider under the loco? A two-rail loco or a three-rail loco without slider will not work on three-rail track.
Offline dietcoke777
#8 Posted : 10 November 2016 04:09:24(UTC)
dietcoke777
Hong Kong
Hi Tom - need to trouble you again - since I will be in Frankfurt and Düsseldorf next month can you recommend a neighbourhood eisenbahnshop that might be able to troubleshoot the problem, reset the decoder address, and/or install a new decoder if needed for me? how much should I expect to pay for this service?
PS-yes it is an AC model. Thank you again!
Offline baggio
#9 Posted : 10 November 2016 05:22:19(UTC)
baggio
I think your simplest solution is to have someone with an MS2 or a Central Station change the address on the loco without even opening the loco.
Go to a dealer/friend, tell him that this is what you want done. EXPECT to pay a fee for the service if you go to a dealer; they, too, need to make a living.
Unless the decoder is an MFX decoder (I doubt it, given the age of the loco, but then you said the decoder was changed), the first thing the dealer/friend would have to do is search for the loco in the database of the controller (this can take some time) and then once the loco is found, he should RUN the loco back and forth for 30 seconds chcking a couple of functions just to make sure all is in order.
THEN the dealer would change the address to one of the four you have.
YOU then check with your own controller (and power supply and 3 feet of track) that the loco does indeed work. Check the lights going on and off and the other four functions you have. (But they may not all work, depending upon the decoder, maybe none.)
Total time on the premises: maybe 30 minutes, more or less.
You then PAY the dealer the equivalent of 25 Euros or so. If no money is asked, then buy something at the store for at least the same amount. If it's a friend, then you decide what to do to thank him.
My two cents' worth.
Hope this helps.
#10 Posted : 10 November 2016 08:23:04(UTC)
[...] the first thing the dealer/friend would have to do is search for the loco in the database of the controller (this can take some time) and then once the loco is found, he should RUN the loco back and forth for 30 seconds chcking a couple of functions just to make sure all is in order.
You cannot find a single Roco loco in the database.
And even for Märklin locos it makes no sense to search them in the database if they have a new decoder.
Don't search the current address, don't search the loco in the database, just set a new address.
Best tool for the job will be an ESU Lok Programmer. Second-best tool will be an ECoS or CS1 reloaded.
The dealers I found so far are dealers, no bit fiddler.
Märklin's website has a Dealer search. Maybe e-mail some dealers that are in reach and ask whether they are willing to help with your problem and which equipment they have for the job.
Will you lend a car? Maybe club meetings or forum members can be an option.
Offline dietcoke777
#11 Posted : 10 November 2016 10:00:18(UTC)
dietcoke777
Hong Kong
Thanks everyone. I found a shop in D-dorf who will be able to help. I really like this Roco version of the Danzas Re 460 so don't mind dropping some euros to get it properly sorted.
thanks 1 user liked this useful post by dietcoke777
Offline baggio
#12 Posted : 10 November 2016 10:08:40(UTC)
baggio
I realized after I posted that being a non-Marklin loco it would not be in the database.... Blushing
Having said that, in the database, one could find a SIMILAR loco and then try to control the loco that way. This is often done using an MS1, even with Marklin locos.
My question for HO is: can you change an address on a loco that is not otherwise controlled by the MS2/CS? If so, how? Thanks.
Offline eroncelli
#13 Posted : 10 November 2016 10:48:52(UTC)
eroncelli
Both the MS2 and CSx have a function called "Find a loco (address)"
That's exactly for the task/purpose you are referring to (i.e. unknown address).
thanks 1 user liked this useful post by eroncelli
#14 Posted : 10 November 2016 11:13:19(UTC)
Expect this function to fail with about 50% of locos.
The MS2 tries all MM addresses, turns on F0 and checks for a change of current draw.
If the loco has no lights on F0 (e.g. Delta locos) or warm-white LEDs then there won't be a significant change in current draw and the address cannot be found.
If you buy a second-hand loco and are about to change the address anyway, then don't bother finding the current address if you can simply set a new address.
In case of MS2, I would create a new loco entry with "MM programmable" and any address.
Then edit the loco and change the address - the MS2 tries to write the new address to the loco and if that succeeds then loco and MS2 will use the same address and loco should work.
Previous address of the loco gets lost.
If you want to set the loco to e.g. address 17, then maybe create a new loco with address 16. Then edit the address to 17.
The same procedure will work with the CS2, too. I'm not sure whether the dummy address trick is needed with a CS2.
The ECoS has an MM programming page and a DCC programming page where you can change loco settings without registering a loco.
If you want to program a turnout decoder with a CS2 then you will have to use a loco entry to make the changes because the CS2 lacks those programming pages that work independent from any loco entry.
Offline baggio
#15 Posted : 10 November 2016 13:11:57(UTC)
baggio
Thank you, Eroncelli and HO, MUCH appreciated.
This is really helpful information for all of us in dealing with used locos. ThumpUp BigGrin
Offline dietcoke777
#16 Posted : 10 November 2016 15:03:26(UTC)
dietcoke777
Hong Kong
Time for you to write a book Tom. I'd buy one... or ten.
Offline dietcoke777
#17 Posted : 03 January 2017 14:24:06(UTC)
dietcoke777
Hong Kong
I just spent an amazing week in Dusseldorf, Germany and the guys at Menzels Lokschuppen & Töff-Töff helped me to change the Roco Danzas decoder address in literally less than a minute. I bought a BR146 DB Cargo (with LokPilot V4.0 decoder) off them and here is a picture of both trains running together on the same address. Together with ebay.de purchases I bought back a significant amount of rolling stock to go with the two trains.
In fact I just bought 45 C track pieces including 24671/24672 minutes ago to expand my big oval set up compromised of 85 C tracks and I am holding my breath for being able to run it all on a single 36VA transformer :)unnamed.jpg
#18 Posted : 03 January 2017 14:45:18(UTC)
Looks like BR 145.
Changing the address of a LokPilot 4 with the IR controller should be no problem.
Good to hear your problem was solved. Thanks for the feedback.
This page was generated in 0.572 seconds.
