Offline poppa-7
#1 Posted : 02 November 2016 08:18:10(UTC)
poppa-7
Hi Everboby
Small problem maybe a big one. I have one CS2 and two MS2's. I use the lefthand MS to control trains running in the lefthand direction and the righthand MS to control trains running in the right hand direction. I use the digital card to transfer the loco from the CS to the MS with no problem I have also tried the MS procedure as well but when i want to transfer a MU set to the MS it appears that i could be doing something wrong. However I get the distinct impression that this operation may not be possible. Any body got any clues.
Russell
#2 Posted : 02 November 2016 09:12:35(UTC)
Are the MS2s connected to the CS2? In that case you can use the loco list to select locos, no loco cards needed. And MUs should also be in the loco list.
If the MS2s are not connected to the CS2, then there is a problem: the MS2 does not support MUs.
Offline poppa-7
#3 Posted : 06 November 2016 09:13:18(UTC)
poppa-7
Hi Tom
Yes the MS2 are connected to the two outlet in the front of the CS2 but I still don't seem to be able to fine the correct procedure to transfer the MU.
I have read both the CS2 and the MS2 manuals but cant make it work.
Any more advise for me.
Russell
#4 Posted : 06 November 2016 13:16:22(UTC)
See page 23 in the MS2 manual, section "Assuming Control of a Locomotive from the Central Station".
I don't know whether MUs show up in the loco list, but I expect them to be there - and I also expect them to be controllable from the MS2.
This page was generated in 0.358 seconds.
