Offline danmarklinman
#1 Posted : 24 October 2016 17:10:36(UTC)
danmarklinman
Hi is their any special way of loading a Piko hobby range loco onto your Marklin mobile station 2. I has an address of 3. Do I load in address 03 0r 003 0r just 3Confused please explain Piko AC owners please.BigGrin
the loco I have, I have talked about on this thread. - https://www.marklin-user...n-MFX-sound-decoder-help
thanks Dan
Wiking model car Fan
Instagram: marklin1978
Wiking fan
#2 Posted : 24 October 2016 17:19:14(UTC)
Hi Dan,
Where are you trying to enter the address?
What I do is that I enter "New Loco" in the menu, select "enter manually", then select "MM2 programmable", then on the "address" screen I click on + until I get to the right address, in this case "3".
Is there another way?
#3 Posted : 24 October 2016 17:24:04(UTC)
danmarklinman
Hi Dan,
hi Ray. yes into the mobile station 2, new loco. I will have a go with your instructions later, unless its different on the Ms2.i don't have a central station yetCrying . thanks Dan
Wiking fan
#4 Posted : 24 October 2016 17:34:51(UTC)
Hi Dan,
This is on the MS2. Sorry I should have made it clear.
Unfortunately I don't own a CS2 or 3 (yet) BigGrin
#5 Posted : 24 October 2016 21:12:12(UTC)
Do I load in address 03 0r 003 0r just 3?
With MS2 there are no leading zeroes. It is just 3.
I would use DCC (not MM programmable) for all locos that support DCC.
With DCC you get more speed steps and more functions (makes no difference for your soundless loco).
#6 Posted : 24 October 2016 21:20:53(UTC)
danmarklinman
Hi thanks for the info, how do I select FCC on the ms2 cheers Dan
Wiking fan
#7 Posted : 24 October 2016 21:44:09(UTC)
Hi thanks for the info, how do I select DCC on the ms2
When you create a new loco, just scroll down on the screen that shows "MM programmable".
You cannot change this for loco entries you already created.
#8 Posted : 25 October 2016 19:59:34(UTC)
danmarklinman
Hi, thanks for the info, again. I have loaded it on to the ms2 and it it runs great. Nice smooth speed steps. There's no need for any new decoder at all. I may get a DCC stay alive decoder, I'm not sure. But it runs through double slips and curve points without any problems.
Wiking fan
This page was generated in 0.442 seconds.
