Offline Rocca
#1 Posted : 15 October 2016 17:37:21(UTC)
Rocca
Dear Märklin Friends,
I need your help. I tried today to connect my CS1 with my PC. I'm having now Windows 10 and so I suppose the troubles depending on that. I have too a router now (KRAUN Adsl). Anyway, when I check my settings for the IP address in the Tools I find the IPv4 address and then set it on the CS1 with the Gateway IPv4 address too. But when I restart my CS1, I can't see the Setup Page on my browser, The red light on the CS1 is red, as in the Instructions.
Has had anyone the same trouble? Any suggestions, pelase?
Offline French_Fabrice
#2 Posted : 15 October 2016 19:00:20(UTC)
French_Fabrice
Hi Stefano,
You may have not compatible IP addresses between the PC /router and CS.
Try to see here https://www.marklin-user...ps-and-tricks#post456312
and next post (#6) to see if the IPs are in the same subnet.
An other tip: From your PC, open a dos/shell console and enter "ping <IP_address_of_the_cs>". If you get reply then it's ok.
Fabrice
thanks 2 users liked this useful post by French_Fabrice
#3 Posted : 15 October 2016 19:00:51(UTC)
Have you tried to connect network automatic with the router and the CS1?
Maybe you did checked wrong by write numbers wrong?
Offline Rocca
#4 Posted : 16 October 2016 11:49:58(UTC)
Rocca
Hi Fabrice,
Thank you so much for the help. I checked it again and now it works. I suppose I've been misunderstanding about the IP address to put on my CS1, but anyway the Instructions by Märklin are quite clear...BigGrin BigGrin
I needed that for saving a backup of the system. It is like mcs_backup.mcs ?
Am I right?
Best regards and thank you again
Stefano
Hi Stefano,
Fabrice
Offline Rocca
#5 Posted : 16 October 2016 11:51:53(UTC)
Rocca
Hi Goofy,
I tried that too, yess, but I haven't a DHCP Server in my pc...!!Huh Huh
Good Sunday to you
Stefano
#6 Posted : 17 October 2016 21:32:40(UTC)
Originally Posted by: Rocca Go to Quoted Post
Hi Goofy,
Good Sunday to you
Stefano
Routers typically have DHCP servers built in, to facilitate the NAT system one typically uses in a home network.
"router now (KRAUN Adsl)"
Offline Rocca
#7 Posted : 19 October 2016 23:01:00(UTC)
Rocca
Hi, Minok,
If I look at the properties of my Internet connection it tells that the DHCP is not available.
Stefano
Hi Goofy,
Good Sunday to you
Stefano
This page was generated in 0.311 seconds.
