#1 Posted : 11 October 2016 17:11:24(UTC)
Trying to source plastic wheel sets for the standard size wagons and coaches (don't ask why its complicated lol)
Tried dealers without success and still waiting on a reply from Marklin. Any help appreciated.
#2 Posted : 11 October 2016 18:24:59(UTC)
The only plastic wheel sets I know Marklin have done have been for Z gauge. If you want them for running you quickly swap them out for metal wheel sets.
If you want insulated wheels for 2-rail running, then look at the wheel set equivalents marklin give in the catalogs for all the wagons.
#3 Posted : 11 October 2016 18:42:02(UTC)
As I understand, the Italeri wagon kits come with plastic wheel sets. Maybe these are available as spare parts?
See http://shop.italeri.com/...-with-brakemans-cab.aspx
Ray, you are building these kits - can you verify my assumption regarding the wheel material?
#4 Posted : 11 October 2016 18:58:31(UTC)
Or the "obvious" solution... BigGrin
Or search ebay for Jouef plastic wheelsets... Hornby owns Jouef nowadays, I think...
This UK seller has more than 10 sets (x10) available
http://www.ebay.co.uk/it...hes-wagons-/152254588998
Edit - I just ordered one 10-pack for myself, to see if they are compatible with standard M wheels with the same axle end type... Wink
#5 Posted : 11 October 2016 19:59:12(UTC)
Thanks guys. Will have a look at the above. This is why this site is so good.
#6 Posted : 11 October 2016 21:33:09(UTC)
Yes you are right. The wheel sets are plastic. I swapped them for some Lilliput wagon wheels I had spare.
#7 Posted : 12 October 2016 11:18:02(UTC)
Thanks Ray. Must have a go at one of the Italeri kits.
#8 Posted : 17 October 2016 21:03:24(UTC)
Got the Jouef spare part wheels today.
They are of a larger diameter, both the wheels and the axle. This is compared to a "standard" Märklin wheel from the 4423 basic flat wagon.
They could be used for a static display of a wagon, though.
For running, no way...
This page was generated in 0.502 seconds.
