Offline Johnvr
#1 Posted : 09 September 2016 15:52:21(UTC)
Johnvr
I have a question regarding how you have set up your programming track ?
Is your Programming Track integrated into your layout ?
If so, what sort of switching mechanism to you use to switch the track between Main and Programming ?
What is the possibility that a loco could run from your Programming track onto the Main track, and if so, what will the effect be if there is an accidental connection between the two ?
Regards,BigGrin
#2 Posted : 09 September 2016 16:11:31(UTC)
Hi, John!
Is your Programming Track integrated into your layout?
Yes.
If so, what sort of switching mechanism to you use to switch the track between Main and Programming?
None.
The Central Station has a relay inside. While programming mode is not active, nothing can happen when a train passes between Main and Programming.
I have to make sure no rolling stock bridges between Main and Programming when I activate programming mode. So far nothing bad happened when I didn't pay attention.
The Central Station 2 has no relay. The Programming track is limited to 1 A - this could be an issue when running demanding trains over the programming track.
While programming mode is not active, there cannot be problems with trains passing between Main and Programming.
Just make sure no rolling stock connects Main and Programming when you activate programming mode.
And external switch can be used for double security or to bypass the 1 A limit.
The Intellibox is like the Central Station: there is a relay inside.
#3 Posted : 09 September 2016 21:33:00(UTC)
So putting the programming track on a dead-ended siding track at the rail yard or near the controller station may be a good idea, right?
The CS handle continuous driving of the locos across the isolated section of programming track smoothly I take it?
Offline Johnvr
#4 Posted : 10 September 2016 11:40:08(UTC)
Johnvr
Fortunately I have got a convenient siding which I decided to convert into a Programming Track.
A selector switch has been installed in the siding to take current (Red+Brown) either from the Main or the Programming.
In addition, the Main gets switched off when Programming takes place.
thanks 3 users liked this useful post by Johnvr
#5 Posted : 10 September 2016 12:35:52(UTC)
Nup.. I use a roller stand..
Offline Legless
#6 Posted : 10 September 2016 12:52:48(UTC)
Legless
You can isolate a piece of track and using a three way switch wired power to the programming track/off/main track power.
Legless
#7 Posted : 10 September 2016 13:01:22(UTC)
Regards,BigGrin
Hello John,
Good move and looks nice and convenient ThumpUp
My own alternative (thanks Matt Smile for the original advice) is to use a LokProgrammer via a short separate track then connected to my computer.
(the Märklin archeologists amongst us will tell you I am still on-track in the prehistoric ice age with my 6021's on the actual layout but I am very happy with this arrangement !! )
PJ BigGrin
Offline PMPeter
#8 Posted : 10 September 2016 15:21:13(UTC)
PMPeter
I use my front station platform track as my programming track. I isolate the pukos using the Marklin isolators and the rails using the Peco isolated rail joiners for my K track at each end of the section. I then have a 3 way switch (Track power - Off - Programming) to provide the appropriate power to this section of track.
I also have the 3 way switch so that the programming track selection is in the up position. So in case something drops on the switch toggle it doesn't accidentally put the track into programming mode.
For me this works out very well.
thanks 2 users liked this useful post by PMPeter
#9 Posted : 10 September 2016 18:32:52(UTC)
Short of a warning horn and H0 scale warning light to indicate programming mode also controlled by the switch, that's about as safe as one can get and blend in nicely. Well maybe a designated bay in the Lokschuppen with special markings.....
Offline Moritz-BR365
#10 Posted : 10 September 2016 21:08:09(UTC)
Moritz-BR365
It could be done like this:
Offline Ross
#11 Posted : 07 March 2019 21:04:11(UTC)
Ross
Hi All,
I have used this method for a drive on programming track.
Programming Track Wiring
Link corrected 01-01-2025
Edited by user 01 January 2025 04:33:05(UTC)  | Reason: Not specified
Ross
Offline amartinezv
#12 Posted : 08 March 2019 10:06:44(UTC)
amartinezv
Hello
My digital central is an IntelliBox and my programming track is completely separated from the layout.
Antonio Martínez
www.raildigital.es/davidruso
This page was generated in 0.403 seconds.
