Offline Jabez
#1 Posted : 08 September 2016 18:29:13(UTC)
Jabez
Some new Marklin locos are stated to have controlled high-efficiency propulsion while others feature controlled high-efficiency propulsion with a flywheel.
I suppose the flywheel makes for smoother running, especially at slow speeds when stopping or starting under digital control.
Is this so? And if so, does it really make an important difference?
#2 Posted : 08 September 2016 19:50:19(UTC)
The ones with flywheels are of the newer design, using so called "can motors" or better "Faulhaber style motors" (the ones Märklin calls funnily "bell shaped armature" BigGrin )
And yes, if the decoder has been properly matched to the engine/transmission characteristics, this solution offers very nice performance.
The simple "High efficiency propulsion" are of the older design, which are basically an evolution of the original Märklin motors from the late 1930's, of which we have had successively LFCM, SFCM and DCM 3 pole versions, and the current evolution is a 5 pole with permanent magnet inductor.
This is a tested and true design: with a number of my loks going over 65+ years, I just have had to replace brushes and for some the gears (after 50 years of service!)
Again, when decoders are properly matched, they offer **very decent** performance and good traction, albeit a bit noisier in most case than the "can-motor" designs.
Hope this helps
Jacques
#3 Posted : 08 September 2016 20:20:45(UTC)
Flywheels can make a big difference - e.g. when the loco loses power (track power turned off or bad contact). The cars may derail if the loco stops abruptly while the train is in a curve.
Properly sized flywheels will prevent this.
However some flywheels are too small to be effective.
Flywheels? (H0-scale)
by Bill 10/03/2002 23:56:23(UTC)
This page was generated in 0.260 seconds.
