Offline kokomo
#1 Posted : 02 July 2016 22:17:42(UTC)
kokomo
Argentina
Hello everybody
I am a long time DC modeller, but decided to switch to 3-rail world not so long ago after I "inherited" an SBB/CFF starter model equipped with a digital locomotive and control (both shown).
The set came with C-track, which is rather easy to wire, and this is my first attempt using K-track.
I am trying to build a simple stub track, length around 140 cm long, where I can test my locomotives and I have some unforeseen difficulties wiring it.
I welded solid copper wire (red) to the center rail at each side of this test-track and I used some Atlas rail feeders I had for supplying electricity to the outer rails (black).
The thing is after connecting the trafo and the Mobile Station to the little grey box and both corresponding wires, the loco does not move at all. As if the MS did not recognize it at all. I know this connection is not definite but I want just to know if electrically is viable and without any short circuit.
What am i doing wrong here? Confused I thought it was dead easy Glare I know that some extra soldering needs to be done to some tiny gaps at the track but I have placed the loco on every single part of the track and the result is the same. Cursing
Any suggestion is really welcome
Modeling Central European trains. Eras III, IV and V
Mostly UserPostedImage UserPostedImage UserPostedImage but can also get some French or Italian articles too
#2 Posted : 02 July 2016 23:06:46(UTC)
It should be easy.
Does the loco move on C track?
Does the loco move when you hold red at the centre slider and brown at the wheels?
Is there power on the track? You can test it with a multi-meter (AC range) or a light bulb.
Which starter set is it?
Offline kokomo
#3 Posted : 02 July 2016 23:14:36(UTC)
kokomo
Argentina
Hi, thanks for the prompt reply.
Set is # 29483 and loco works fine on C track.
Dont have a tester with me. Wiring for digital needs anything special?
#4 Posted : 03 July 2016 08:19:04(UTC)
Not really.
Your rail joiners leave a gap between the rails. Maybe the centre-rail connectors do not make contact there. Maybe only parts of your test track have power.
Or maybe another gap elsewhere. A light bulb or a continuity tester might be helpful here.
Hold a wire between centre rail and outer rail and the STOP light should go on on the MS2. You can try to make a short right between the feeding points and try again further away.
Offline kokomo
#5 Posted : 03 July 2016 18:19:39(UTC)
kokomo
Argentina
Thanks.
What is weird is that both red central wires do not work. That's strange. I do have a tester, now that I think about it, but never used it that's why I did not recall owning one. Electricity in all its ways is not my strongest point.
In case I use the tester, i should put the red wire to the puko in the center and the black one to one of the rails?
I asked about wiring for digital because I read that Marklin had a feeder rail piece exclusive for digital and one for analogic.
#6 Posted : 03 July 2016 20:52:08(UTC)
For analogue layouts you need a feeder rail with capacitor and additional feeder tracks without capacitor.
For digital, all feeders should be without capacitor (otherwise the loco will run a few seconds only).
With a voltmeter (AC) you should test with red at the studs and black at the outer rails. Also check directly at the track box and in between until you find the interruption.
Don't pay attention to the volt reading - just look for greater 0 or 0.
Offline kokomo
#7 Posted : 03 July 2016 23:33:13(UTC)
kokomo
Argentina
Ok, so I went back to the track and tried first to check if the loco was operational (I was 99% sure it was, but just in case). It worked
Then I put the loco on the track and directly connected the wires from the Marklin grey box to the rails. It worked
However there were some parts of the track, both ends, where it did not run. It seems the welding was not good there so I had to improve it and after some testing it worked.
Here, a short video...
Now my next challenge, the big viaduct...
ps: one question, if you feed only one of the rails instead of both, will the loco still run or does it need both?
#8 Posted : 04 July 2016 08:32:03(UTC)
It's better to feed both outer rails - contact and conductivity will be better. Locos should work more reliably.
Offline kokomo
#9 Posted : 05 July 2016 15:12:14(UTC)
kokomo
Argentina
Thanks. It was just a doubt I had (if it was technically viable)
This page was generated in 0.444 seconds.
