Offline Pmare4
#1 Posted : 04 June 2016 03:19:37(UTC)
Pmare4
Hi everyone
I bought this old T790 along with a few other locos earlier this year.
Unfortunately, the whole lighting assembly is missing and the insulation has been snapped in half. (it should go over the gap that is between the 2 cylinders)
I have looked for the parts at Ritter and TTN, but I have not found any for sale. Perhaps one of the other forum members here has the correct parts? I have attached some pictures, as they may be of help to some members.
The loco itself.
The inside of the loco.
Another view
The bottom of the loco.
Many thanks,
Peter.
Offline Iamnotthecrazyone
#2 Posted : 04 June 2016 05:36:23(UTC)
Iamnotthecrazyone
were you able to find any pictures of what the original part looks like?
Offline Pmare4
#3 Posted : 04 June 2016 07:35:56(UTC)
Pmare4
Yes, I found some here: https://www.marklin-user...t-a-sweet-1950-T790.aspx and here: http://alte-modellbahnen.xobor.de/t21763f2-T.html
I could probably cut the part out of some tin, but the problem is that the locos above both have the part mounted differently. Confused
#4 Posted : 04 June 2016 10:57:43(UTC)
Iamnotthecrazyone
I don't think they are that different in the second link (which didn't work for me as a link) they show two different versions of the same loco. The first one of those have the reversing unit but the plate might be about the same - you just can't see it properly- the second loco which seems to be like yours may have a hand made plate.
Personally I would just buy a sheet of brass -may be about 1/3 of a mm thick- cut it, shape it, find the right screw and voila! you might have to insulate the new plate from the body, it's hard to tell just by looking at the photos. You will need the black double lamp holder which presumably?? might be the same as the ones from f800, da800, 3005 etc.
thanks 1 user liked this useful post by Iamnotthecrazyone
Offline Tiki734
#5 Posted : 04 June 2016 15:27:50(UTC)
Tiki734
If you want original parts unfortunately you might have to buy a scrap loco off ebay. They come up reasonably often but depending on the condition can be expensive. I've got a scrap one which I hope to fix up so I can't offer those parts. I did pick up some SK800 parts last week and there looks like the front end of a T800 is included. It should arrive in about 10 days and I will check it out.
thanks 2 users liked this useful post by Tiki734
Offline Tiki734
#6 Posted : 19 June 2016 13:41:09(UTC)
Tiki734
The parts arrived last week unfortunately it is not complete and has one of the bulb holders missing.
Offline Pmare4
#7 Posted : 23 August 2016 11:47:59(UTC)
Pmare4
Problem solved! BigGrin Laugh Smile
I'd like to thank forum member ixldoc (Howard) for making a new part out of brass - I couldn't have done it any better.
The loco is now doing its rounds on the layout perfectly!ThumpUp
thanks 4 users liked this useful post by Pmare4
This page was generated in 0.393 seconds.
