Online polabear
#1 Posted : 26 March 2016 15:57:34(UTC)
polabear
Hello all,
My apologies if this has been covered in previous postings, but can anyone tell me the correct track useage to properly align the 5754 roundhouses with the 7186 turntable. I am using two 3-stall roundhouses and can't seem to get the right spacing between them while maintaining the correct track angles. Any advice would be most appreciated.
Regards, Dave
Offline carlos.rivas.16752
#2 Posted : 26 March 2016 16:22:17(UTC)
carlos.rivas.16752
Are you using C track?
My layout is M track and I placed the, turntable and roundhouse by trial and error...It worked for me.
Carlos
My blog both in Spanish and English: https://grunewiesen1965.wordpress.com
thanks 2 users liked this useful post by carlos.rivas.16752
#3 Posted : 26 March 2016 16:24:39(UTC)
carlos.rivas.16752
Or maybe this is what you are looking for
thanks 1 user liked this useful post by carlos.rivas.16752
Offline Markus Schild
#4 Posted : 26 March 2016 17:09:03(UTC)
Markus Schild
Hi Dave,
The roundhouse can be used only either with the first three or second three connectors of the six which are together. While the angle between these connectors is 15°, the angle between the connectors 3 & 4 is 17.5°.
Märklin uses two 5106 and one 5109 (3/16) for the rails in the shed.
This picture is correct for 7186:
Markus
Offline Shamu
#5 Posted : 27 March 2016 00:20:21(UTC)
Shamu
Howdy Dave,
As Markus mentioned the spacing between the first and second group of 3 tracks is 17.5° so you need to get the additional Vollmer part to put between or in the middle of the roundhouse.
I'm sorry but I can not recall the part number but will see if I can find my instruction sheet to find it for you.
OK, found it;
Vollmer part # 45256
The parts are included in the 6 stall kit 5758 so maybe someone who has built it for the 7286 turntable may be able to help you out.
thanks 2 users liked this useful post by Shamu
Offline biedmatt
#6 Posted : 27 March 2016 03:26:00(UTC)
biedmatt
Hi Shane, I see the small piece between the sets of three in Carlos' picture. You state they are included in the six stall kit, are they a seperate bag of goodies?
Matt
Era 3
Offline Shamu
#7 Posted : 27 March 2016 09:14:32(UTC)
Shamu
Don't know Matt,
Both my kits are still in the boxes and are further boxed ready for the move.
I'm just going by the instruction manual I downloaded, it just lists the part numbers;
20956/7/8/9
20958/9
20960/1/3/4/5/6
20971/2/3/4/5
Think that's all of them. They are listed in the package contents.
Offline biedmatt
#8 Posted : 27 March 2016 11:53:13(UTC)
biedmatt
Dave, I just bought three of the six stall kits. Since I will be using these with the new turntable, I will not need those parts. I could send them to you if it would help.
Matt
Era 3
Offline biedmatt
#9 Posted : 27 March 2016 23:37:12(UTC)
biedmatt
Hi Shane,
I'm coming up with 15 parts, but you have 17. Are the two parts shown in bold below duplicated in your first row of parts?
I want to make sure before I send these bits to Dave.
20956/7/8/9
20958/9
20960/1/3/4/5/6
20971/2/3/4/5
Matt
Era 3
Offline Shamu
#10 Posted : 28 March 2016 07:01:37(UTC)
Shamu
Yes Matt, a boo-boo on my end there. I doubled up.....Blushing I think I intended listing them in regards to where they went but must have changed my mind.
One part I think I forgot to list is they use 2 of the girder frames #11124 at the connection point with the 29060/1 spacers at ground level. 60 goes to the front and 61 to the rear. I assume they are different lengths to accommodate the angle...... could be wrong though Confused
I can no longer find the manual online so I'm being a naughty boy
Vollmer_45758_6_Stall_Roundhouse.pdf (526kb) downloaded 113 time(s).
Offline Br502362
#11 Posted : 28 March 2016 09:17:04(UTC)
Br502362
Vollmer sells a kit 5256 which is used to connect two pieces of three stall kits together when you
use Märklin 7186 turntable.
eBay.de VOLLMER 5256
Åke
thanks 3 users liked this useful post by Br502362
Offline biedmatt
#12 Posted : 28 March 2016 12:30:12(UTC)
biedmatt
Dave, Åke found the best solution, but I have the parts ready if you want them. There are 15 parts in total. Four roof panels (top left), four gutters (bottom center), four wall pieces (front, back and two risers between the roof levels), the iron work at the peak (center right) and lastly, two pieces that connect the base of both three stall roundhouses together (top right).
Edit: Perhaps I am missing them, but I do not see the iron work piece nor the four gutters in the auction picture.
Edit2: added picture of parts
Matt
Era 3
#13 Posted : 28 March 2016 12:43:15(UTC)
carlos.rivas.16752
Dave, Åke found the best solution, but I have the parts ready if you want them. There are 15 parts in total. Four roof panels, four gutters, four wall pieces (front, back and two risers between the roof levels), the iron work at the peak and lastly, two pieces that connect the base of both three stall roundhouses together.
I don't know for sure but I guess the gutters come with the three stall kit...
Offline biedmatt
#14 Posted : 28 March 2016 13:36:47(UTC)
biedmatt
Hi Carlos, The kit also includes some extra wall pieces, but I am guessing they are supplying the whole tree and not the individual parts.
Edit: The gutters were on the tree with the other gutters and the iron work was on the tree with the other iron work pieces.
Matt
Era 3
This page was generated in 0.747 seconds.
