#1 Posted : 14 March 2016 11:14:42(UTC)
Version: 1.17.19.1 (7. März 2016)
ChgReq: Für Spur H0 Decoder als Funktionsdecoder in Spur 1 Wagen. Der Stromimpuls für die DCC Programmierung, alternativ ohne einen Motor erzeugen.
... googly...
Version: 1.17.19.1 (7 March 2016)
ChgReq: For H0 decoder as a function decoder in lane 1 car. The current pulse for the DCC programming, alternatively produce without a motor.
Files received.
-rw-r--r-- 1 root root 28172 Mar 10 2016 mLD-v1-17-19-1.fwd
-rw-r--r-- 1 root root 5189 Mar 10 2016 mLD-v1-17-19-1.html
ChangeLog
http://xxx.xxx.xxx.xxx/c.../fwd/mLD-v1-17-19-1.html
??? reference to item 58341, 58342, 58343, 58344 ???
Edited by user 16 March 2016 10:40:23(UTC)  | Reason: Not specified
#2 Posted : 14 March 2016 19:17:14(UTC)
As I understand, update for H0 decoder when used in Gauge 1 making it react to DCC programming voltage levels when no motor is present ...
#3 Posted : 14 March 2016 19:55:27(UTC)
H0 decoders can be used as function decoders with 8 outputs (no motor output).
With DCC programming, the decoder has to increase the current draw for feedback to the controller. Normally the motor outputs are activated - but the decoder was configured for a motorless mode; Märklin changed the mode used in this case. But they don't say how they changed it.
Offline mbarreto
#4 Posted : 14 March 2016 23:12:04(UTC)
mbarreto
One advantage of CS2 is we always are able to understand a portion of what it can do.
I am sure with CS3 we will also have that advantage and maybe a miracle will make us understand all it can do.
Miguel
Mostly Märklin H0.
#5 Posted : 16 March 2016 10:26:58(UTC)
Looks like the 1.17.19.1 was not for general use (yet)
For those who had done an update in the last 48hrs, the *.1 files still exist on the CS2.
However I am pretty sure that this back-out would imply that they should not be used.
This page was generated in 0.418 seconds.
